» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Roadster Forums > R129 SL Class
Old 06-25-2007, 10:59 PM   #11 (permalink)
lynns's Avatar
Date registered: Jul 2006
Vehicle: 2000 SL500 Sport
Originally Posted by Bagger Lance
I'm not certain there is a parallel between transmission seals and convertible top seals, but if there is common ground it would be very interesting to know the details.
I'm sorry but I wasn't suggesting a change in the tranny oil for the benefit of only it's seals but for the benefit of the whole transmission, gears, etc.
I was trying to draw a parallel between the two because I have been told that M-B says that the 722.6 tranny is 'filled for life' and I also heard that M-B says that the hydraulic system is 'filled for life'.
lynns is offline   Reply With Quote
Old 06-25-2007, 11:46 PM   #12 (permalink)
Date registered: Feb 2007
Vehicle: 99 SL500 AMG, 97 c230, 07 F150 FX4 crew
What is life?
"filled for life" is an interesting term. In the work I'm paid to do I create concepts for new products, launch them into the global market and then manage their lifecycle.
Product "life" has a specific meaning to manufacturers from a service and support standpoint, but not from a product usability standpoint. I've spent countless hours in meetings discussing Mean Time Before Failure (MTBF) with Engineers and Service groups on products we build.
As consumers, we define product life in human terms based on useability alone. In other words, until the product fails whether it was within a guaranteed time or not.
Lifetime warranties or product life in general is not measured in human terms. They are measured in product lifecycle terms and the product lifecycle is up to the manufacturer to decide.
In any case, I would like to understand if refreshing the soft top fluid has any bearing on increasing the "life" of the composite seals. They apparently have an average 5 to 10 year MTBF depending on environmental conditions. Is the fluid an environmental determinate?
Bagger Lance is offline   Reply With Quote
Old 06-26-2007, 02:12 AM   #13 (permalink)
lynns's Avatar
Quite a bit of discussion has taken place around your question. I for one believe that renewing the HF could increase the life of the seals. I don't believe I would call the fluid an 'environmental' factor but I would consider temperature and pressure, etc. acting on the seals and fluid to be be environmental.
Here are some posts with regard to 'filled for life'.
hydraulic leak fix begins
What I Found Inside My 722.6 Gearbox
Old 07-01-2007, 08:27 PM   #14 (permalink)
Date registered: Aug 2006
Vehicle: 300SL-24 1992 White
The Photos for reference
Photos first, writing latter.
morriswu is offline   Reply With Quote
Old 07-01-2007, 08:31 PM   #15 (permalink)
Photo-2
Photo-2
Old 07-01-2007, 08:32 PM   #16 (permalink)
Photo-3
Photos Explanation:
1. The cracked seal, in this damaged manner, I don't thick the "NO LEAK" fluid can work.
2. The tools and new seal with o-ring. The cylindrical tube section is used to "creat" a space between fix spring ring and the cap, without it, very difficult to take rid off the spring ring that hold the cap in position.
The spanner is #5 for this type cylinder #129 800 21 72; for 129 800 16 72 (windshifd)you need #7
3. Take off the cylinder from the assembly.
4. Use some cylindrical tube section and hammer the cap down, to gain space for - driver to work out the spring ring.
5. Take off the holding ring.
6. cylinder parts arrangement
7. New/old seal and o-ring. The food film wrapping the thread is to prevent the damage of seal while installing.
8. detail as above. You may use some suitable dimension straw also.
9. New seal and oring replaced OK. Assemble it would be easier than disassmble, the only step need to take an effort on, is put the spring ring back.
10. Use "LOCTILE" to fixen the thread.
11. The creaked seals
12. The New seals. These 4 “special” dimension seals are all what we want in R129.
13. For open #129 800 17 72 (left),& #129 800 02 72 (right), you need to make a tool like this.
Hope this stuff be somewhat helpful to you.
Old 07-01-2007, 10:43 PM   #17 (permalink)
lynns's Avatar
This is great stuff!
I really appreciate your time taken to add to this ongoing topic.
Thank you so much. At this point we can see the seals and there location, etc.
Old 07-02-2007, 12:44 AM   #18 (permalink)
tjobeid's Avatar
Date registered: Dec 2006
Vehicle: 1995 sl 500 red/black w/renntech wheels
Send a message via AIM to tjobeid
looks easy, im not doing it lol
1995 SL500 red / black w/ ]RENNtech wheels. For sale
1992 sl500 red/tan 154k. 4sale also best offer.
Looking for 1999-2002 500sl or 93-1999 sl600
tjobeid is offline   Reply With Quote
Old 07-02-2007, 01:20 AM   #19 (permalink)
Date registered: Jul 2005
Vehicle: Black SL 500 1994
Thanks for the post morriswu! :-)
Did I understand correct, that these (4 "special" dimension seals) are the ONLY parts which need to be changed to repair the leaks?
And specificly and most importantly:
WHERE CAN I BUY THESE SEALS???
ErikFinn is offline   Reply With Quote
Old 07-02-2007, 01:38 AM   #20 (permalink)
Hi ErikFinn,
In normal operation, that is the only seals and o-rings necessary. I have fixed all my 10 cylinders by myself.
Later, I will post the seals' and orings' dimension and you can search them. There must be somewhere in the world a vender can provide, but I really don't know where it is.
I had a friend make the molding dies and manufacture those seals.
POLL - Convertible Top Hydraulic Cylinder R&R lynns R129 SL Class 105 10-22-2009 06:27 PM
Vario roof main hydraulic cylinder removal Bazzle R170 SLK Class 10 10-05-2007 01:56 PM
help! hardtop hydraulic cylinder gpreyes R170 SLK Class 14 05-06-2007 06:53 AM
Yet another question on hydraulic cylinder kyericho R129 SL Class 3 11-17-2006 12:08 PM
hardtop hydraulic cylinder, which ones are more prone to error kyericho R129 SL Class 11 09-20-2006 04:30 PM
