ATF - automatic transmission fluid - 722.6 five speed automatic - Page 10 - Mercedes-Benz Forum
post #91 of 193 (permalink) Old 01-16-2009, 08:38 AM
Myndex's Avatar
Date registered: Jan 2009
Vehicle: 1980 450SL named Freya. 202,000mi
Quoted: 138 Post(s)
My assumption is that for the newer "never needs changing" tranny, they are using a synthetic ATF, and that is $$$. Using Dexron in a tranny using synthetic is a recipe for disaster IMO.
A
Myndex is offline
post #92 of 193 (permalink) Old 01-16-2009, 09:14 AM
NEOKEN's Avatar
Date registered: Dec 2007
Vehicle: 95 SL500, K&N, NEOKEN Ported TB, Custom Intake, RENNtech Sport Exhaust, AMG I Monoblocks
Quoted: 30 Post(s)
Smile
Originally Posted by masaki@japan View Post
Dear KEN san.
You know japanese lang.! doumo arigatou gozaimasu!(thank you very much)
$250 is "ONLY" change the ATF, not change filter and gasket.
I think if we ask dealer for ATF and filter and gasket, we have to pay around $400-$500.
But we can purchase filter and gasket by $30 in japan.
I've serched for cheapest factory ATF, cheapest is $20 by quarts and dealer price is around $30-35.
And about ATF change.
My friend has 722.3 tranny mercedes and he saids torque converter in 722.3 tranny has drain prug so he can change whole ATF when he will do the ATF change operation.
I wonder torque conv. in 722.6 has drain prug or not.
Masaki san.
Yes I know some Japanese as I was born in Taiwan (raised in US) and most Taiwanese or Chinese know at least the common Japanese terms as we are 'somewhat' connected in our cultures.
Back to the topic...
As for $400-$500 usd. for a transmission service that would be hella expensive here in the US.
Also It is highly recommended to only replace the amount of fluid in the pan only!!!
Do not replace or flush all of the ATF in the system as there is a possibilty to damage your transmission's internal components!!!
Very important!!!
Please read post #27-33 from this thread:
http://www.benzworld.org/forums/r129...e-trans-2.html
NEOKEN is offline
post #93 of 193 (permalink) Old 01-22-2009, 03:06 PM
benge's Avatar
Date registered: Sep 2008
Vehicle: 1995 SL500
Quoted: 4 Post(s)
Originally Posted by NEOKEN View Post
Update:
This is a kind of confusing matter as I just called Leith Mercedes Benz again for further clarification and I was just now told that for these ealier cars they do-not sell MB Dexron-mercon III. What they sell is only Penzoil Dexron Mercon III and it is $4 per quart. and you can get them from Autozone for about $3 per quart. I sincerely apologize for the confusion as this was a matter of communication error somewhere between me and the parts manager. Yes genuine MB does run $15 but for Dexron-Mecron III they do not carry or sell MB brand. I know its Kinda strange...and I am unsure of the reasons and again I do apologize to everyone for the confusion.
So I called our other local deealer Mercedes-Benz of Cary, NC for further investigation and was told the same thing.
Here is their phone number: 919-380-1800
Well It looks like Dexron-Mercon lll is acceptable in the older tranny's. The new seven speed are using synthetic fluid. It seems like the MB price is the same for the old and the new. So I guess if you are going to flush and want to use synthetic you use the new fluid. The new fluid is $14/15 per QT.
benge is offline
post #94 of 193 (permalink) Old 01-22-2009, 11:56 PM
Date registered: Oct 2007
Vehicle: 1988 R107 300SL EURO, 1993 R129 600SL,Toyoita Prius
Send a message via MSN to masaki@japan
Dear benge,NEOKEN,Myndex.
Thank you for your message.
I'd serched to purchase oil,gasket,filter for 722.6tranny in japan.
Cheapest shop in japan sells factory oil 8qt,gasket,filter for $130.
I think it is not bad price, so I will get it.
I broused 722.6tranny oil things in japan and knew that change "only" 3L of drained ATF and filter from pan is best as NEOKEN told me.
I think above work is only 1h.
I will do on next weekend!
But I have to buy Hex wrenches for drain bolt and A/T pan....
masaki@japan is offline
post #95 of 193 (permalink) Old 01-23-2009, 02:25 AM
Moving On
lynns's Avatar
Date registered: Jul 2006
Vehicle: Y2K SL500 Silver
Quoted: 9 Post(s)
Originally Posted by RKH View Post
Try AutoHausAZ.com
I buy most of my stuffs from them and their price are reasonable (cheaper than Dealers). They are located in USA, don't know if they ships overseas.
They don't ship International.
lynns is offline
post #96 of 193 (permalink) Old 01-23-2009, 02:32 AM
Moving On
lynns's Avatar
Quoted: 9 Post(s)
Originally Posted by aam View Post
I think a 92 takes dexron mercon III
With no problems.
That's what I used.
Save money.
Regards.
aam.
He needs to change his User Profile. He just p/u a MY96 SL320 w/ a 722.6
lynns is offline
post #97 of 193 (permalink) Old 01-23-2009, 02:58 AM
Moving On
lynns's Avatar
Quoted: 9 Post(s)
I'd serched to purchase oil, gasket, filter for 722.6tranny in japan.
You should be able to find the Torque Converter bolt and remove an additional 4.5 Liters unlike the newer MY00-02 that did not have a TC bolt. So if you follow these directions at 722.6 Transmission Fluid and Filter Change you should use about 8 Liters. Do not overfill!
In addition, I have learned a few extra things to take care of while you are changing the oil. For p/n's etc. please read Change Trans Fluid and Filter ????
lynns is offline
post #98 of 193 (permalink) Old 01-23-2009, 10:03 AM
RKH
RKH's Avatar
Date registered: Apr 2008
Vehicle: Departed 1998 SL500 (and the Pano is in Bogota)
Quoted: 479 Post(s)
Wait Masaki San: If you have a 1992 500SL (as your new profile says) then it should not have a 722.6 transmission as that did not come out till 1996. I alway thought you have a 1996 SL320 as stated in your earlier post.
RKH is offline
post #99 of 193 (permalink) Old 01-23-2009, 10:12 AM
Date registered: Jan 2008
Vehicle: SL 60 1998
Quoted: 27 Post(s)
Have just had an intermediate service on the SL60
All fluids changed including engine flush and hydraulic soft top system. Costs below.
Oil Filter
1998 SL 60
1991 SL 500 (sold)
nt-j is offline
post #100 of 193 (permalink) Old 01-23-2009, 10:32 AM
Vehicle: SL 60 1998
Quoted: 27 Post(s)
OOPS something happened it was submitted before I had finished Start again
Oil Filter 8.14
Sump Plug Washer 0.90
Mobil Super S 10w 40 Semi 42.00
MB Antifreeze 13.92
Oil Filter 6.45
Gasket 6.70
AT Sump Plug Washer 0.16
AT Sump Plug Seal Ring 0.45
AT Fluid 36.68
ZHM Hydraulic Oil 8.90
Forte Engine Flush 9.95
MBSS Remote Batteries 2 sets 9.90
Waste Disposal 6.95
Sundries 2.95
Labour Charges 3 hrs @ 48.50 145.50
Tax ( V.A.T.) 15% 44.95
TOTAL £344.50 GB Pounds
Loks like they forgot to charge for the brake fluid. oh dear !
This is by an Indie, I wonder how much a main dealer would charge ?
1998 SL 60
1991 SL 500 (sold)
nt-j is offline
Verify correct alternative Trans Fluid for 722.623 trans ??? Pancho C208/A208 CLK-Class 10 02-08-2010 10:11 AM
Trans. fluid and filter change on 91' 300SE nhcamper W126 S,SE,SEC,SEL,SD,SDL Class 5 11-10-2009 01:19 PM
F/S 722.6 and 722.9 Trans Fluid, Brake Fluid, Power Steering MercedesManiac7 For Sale/Wanted/Trade/Giveaway 11 10-07-2009 02:54 PM
722.6 Trans Fluid Change Parts List t28pilot W163 M-Class 4 09-28-2009 03:11 PM
722.6X Transmission Fluid and Filter Change G-AMG G-Class 0 03-29-2007 02:24 PM
