sl 500 window problem - Mercedes-Benz Forum
post #1 of 17 (permalink) Old 04-26-2007, 04:46 PM Thread Starter
Guest
Date registered: Apr 2007
Vehicle: 11 sl65
We stored our 98 sl500 over the winter and disconneted the battery. Now the weather has improved and when taking the car out of storage and reconnected the battery the windows didn't work. We tried syncing windows according to manual but they still will not work. Consequently, the roll bar and top down button are lit and also will not work. Any experience with this?????????
Thanks
xxxxxxxschabey is offline
post #2 of 17 (permalink) Old 04-26-2007, 06:56 PM
tjobeid's Avatar
Date registered: Dec 2006
Vehicle: 1995 sl 500 red/black w/renntech wheels
Send a message via AIM to tjobeid
Disconnect the battery again , put the radio code in then do a reset on your windows which is when you put the hold te windows down at the same time for like 30 seconds i think.
1995 SL500 red / black w/ ]RENNtech wheels. For sale
1992 sl500 red/tan 154k. 4sale also best offer.
Looking for 1999-2002 500sl or 93-1999 sl600
tjobeid is offline
post #3 of 17 (permalink) Old 04-26-2007, 07:15 PM
Undercover Moderator
SL BRABUS's Avatar
Date registered: Mar 2007
Vehicle: SL BRABUS 5.8 Silver Arrow, SL BRABUS B11, S Class diplomat ride, ML55 wife war horse grocery getter
Quoted: 195 Post(s)
check the fuse in the trunk........ good luck...
Horsepower: enough power to go from point A to point B
Torque: enough to get the car moving
0-60 mph: not in a rush
0-1/4 mile: about 5 minutes @ 2mph because no need to showoff
Pictures of my SL collection & Pictures of my S Class ride
My favorite topic, What kind of watch do you guys wear with your Benz...??
SL BRABUS is offline
post #4 of 17 (permalink) Old 04-27-2007, 08:21 AM
We had a similar issue in our 93 500sl. The fuse for the windows and top are located in the trunk near the battery just below the far right side of the trunk lid. They seem to deteriorate more rapidly due to exposure to outgasing of the battery. Check & REPLACE those first and clean the contacts in the fuse holder. I have had this happen when you use the button to retract the top and the weakened window fuse blows as the top starts its cycle. The top button will then flash and top motion will hang-up.
Backert1 is offline
post #5 of 17 (permalink) Old 04-28-2007, 07:43 AM Thread Starter
Guest
Vehicle: 11 sl65
Now window is down, and won't go up
The saga continues,,,we really regret buying this car! After disconnecting battery and syncing windows when we opened the doors, the window went down and now they won't go up, roll bar and topper light are still on!
Now what?
Any comments appreciated!
post #6 of 17 (permalink) Old 04-29-2007, 05:53 PM
Date registered: Jan 2004
Vehicle: '03 SL500, '91 300SL, '91 500SL, '00 S500, '96 C220
Quoted: 205 Post(s)
If your fuses are good, then I think a fault code is set in the soft top control unit or worse, the control unit may be bad. I would have the codes checked. Because this is a '96 or newer car you will need an advanced code scanner to read the codes. These are expensive and typically had only by an M-B repair specialist.
bobterry99 is offline
post #7 of 17 (permalink) Old 05-01-2007, 04:24 PM Thread Starter
Guest
Vehicle: 11 sl65
sl 500 convertible top module
Wouldn't you know it, the simple thing didn't work and not it's time to drag out the green! I was quoted $1857 for installed new module. Car has only 50K. I wish I would have bought another AUDI! Any chance you know of a place where we can get the part for less?
post #8 of 17 (permalink) Old 05-02-2007, 01:10 AM
Date registered: Apr 2005
Vehicle: 2005 350SLK
Now that I am in the market for one, is this a common problem? I would probaby through away the car before I spend this much money on a repair job, but then again, you are stuck and you will not be able to get rid of it before fixing her? Any one else here had a similar poblem with the "module"?
BAZMAN is offline
post #9 of 17 (permalink) Old 05-02-2007, 05:05 AM
msbarsi's Avatar
Vehicle: 2000 Obsidian Black Metallic Mercedes SL 320 V6
Quoted: 8 Post(s)
Send a message via Skype™ to msbarsi
Honestly I've never had a single problem with the car other than a reg number light replaced last saturday and replacing the windscreen 2 months ago because of chipstones from another car (replaced at an insurance top shop and I am an insurance professional) and other than the Check engine light and I'm working on it.
Every car breaks down that's obvious but with the help of the forum the 80% of the spares aren't that expensive especially if you think that these cars were worth well over 80.000 $ when new at least.
Cheers.
msbarsi is offline
post #10 of 17 (permalink) Old 05-02-2007, 06:59 AM Thread Starter
Guest
Vehicle: 11 sl65
After this issue I am truly soured on the car. When I asked the dealer about the cause of this malfunction he said that it usually is caused by jumping the car, which we did not do. Furthermore, when I asked how often he sees it happen, his reply was "it's not that common, we only see about one a week!" Considering that here in MN this car is not that common, it seems like a lot to me. Good Luck!!!
WANT window regulators '84 500 sel 126 birgitnilsson For Sale/Wanted/Trade/Giveaway 0 05-23-2006 08:52 AM
S 500 2000 window problem and more Remax Audio & Telematics Forum 0 09-21-2005 08:22 AM
1997 500 s .. any way to get to window switch/ remove console? aufderheide General Mercedes-Benz 0 10-06-2004 05:02 PM
Outer hard rubber window seals 500 SEC Graham W126 S,SE,SEC,SEL,SD,SDL Class 0 08-22-2003 07:45 PM
500 SEC Outer SIDE Window seals(?) Graham W126 S,SE,SEC,SEL,SD,SDL Class 0 08-20-2003 04:51 PM
