Seat belt stuck - Mercedes-Benz Forum
post #1 of 18 (permalink) Old 03-26-2007, 09:45 PM Thread Starter
patfarrell's Avatar
Date registered: Jan 2007
Vehicle: 2001 SL500
Seat belt stuck
The passengers side seat belt it stuck in. I cant get it to pull out. I more I mess with it the tighter it gets, it was working fine before that. I am going to take the seat apart. Will I need a new seat belt assembly or can I unwind it is this a common problem. It is so tight I cant move the headrest up or down and move the seat back.
patfarrell is offline
post #2 of 18 (permalink) Old 03-27-2007, 12:28 AM Thread Starter
patfarrell's Avatar
Vehicle: 2001 SL500
Ok after taking the seat all apart I got it loose. Then it got stuck again. There is a cable coming from the button if I wiggle it and play with the button for a while it will come loose. But it is a little hard hooking the seatbelt in. I think I will stop by the dealer and look at getting a new seatbelt assembly. Has anyone ever replaced on before know the cost or part number. Thanks
post #3 of 18 (permalink) Old 03-27-2007, 10:21 AM
wayneg's Avatar
Vehicle: 1999 SL500 Sport, Black Opal Pearl, Helios Leather, Pano roof, AMG Aero2 18"Split Rims, Rear Seats
Quoted: 27 Post(s)
Is this fault on the car you picked up yesterday? if so take it back for fixing and beat up the salesman for not checking the car prior to collection.
wayneg is offline
post #4 of 18 (permalink) Old 03-27-2007, 10:42 AM
Carlo$'s Avatar
Date registered: Sep 2003
Vehicle: 97 SL500
could it be the child safety is on?
Carlo$ is offline
post #5 of 18 (permalink) Old 03-27-2007, 11:55 AM Thread Starter
patfarrell's Avatar
Vehicle: 2001 SL500
I fixed it. It worked when I left the dealer. And I gave my mom a ride and I worked. Someone must of dropped piece of a oatmeal bar in the button and it melted and hardened. When I used the seat belt it pushed it down and locked the cable so the seatbelt wouldn’t move. After taking the seat apart and finding the seatbelt was $400 for one half I took another look and saw the melted bar and cleaned it all out now its working good. But I had to spend $300 on a front license plate bracket so I can get the car inspected.
post #6 of 18 (permalink) Old 03-27-2007, 12:09 PM
Carlo$'s Avatar
Vehicle: 97 SL500
i can sell you my front plate bracket. its plastic and the color of my car. we dont use them in ok.
Carlo$ is offline
post #7 of 18 (permalink) Old 03-27-2007, 12:10 PM
josephanthony's Avatar
Date registered: Dec 2004
Vehicle: 2009 SL550 Silver Arrow Launch Edition, 2013 Mercedes Benz C300 4Matic
Quoted: 5 Post(s)
Send a message via AIM to josephanthony
Too bad about the license plate bracket price. If you had more time, you could have found one from someone in this forum who doesn't use it, or online for a whole lot less. We don't need fronts in DE, but I use a deco plate instead of leaving it empty. Glad the belt works now.
"Quiet Storm"
When you change the way you look at things,
the things you look at change.
josephanthony is offline
post #8 of 18 (permalink) Old 03-27-2007, 12:48 PM
wayneg's Avatar
Quoted: 27 Post(s)
My apologies to your car salesman, I think a total food and drink ban now is in order. well done for the DIY fix
wayneg is offline
post #9 of 18 (permalink) Old 04-02-2007, 08:46 PM
wunaswerve?'s Avatar
Date registered: Apr 2007
Vehicle: 1996 Mercedes Benz SL500
Is there a child safety lock? My passenger seatbelt locks into place and won't let the passenger move once fastened. Release the belt and everything is fine. It seems to be connected to the fastening mechanism. Any ideas?
wunaswerve? is offline
post #10 of 18 (permalink) Old 04-02-2007, 11:51 PM
coachb's Avatar
Date registered: Jun 2006
Vehicle: 1998 SL 500
On my 1998 SL 500 there is a button on the lower side of the passenger seat on the door side of the seat that locks up the belt. It had been pushed thru the hole it was seated in and when I set it back in the hole and pushed it the seat belt worked again. Hope this helps
Aaron_SF likes this.
coachb is offline
    seat belt Rahray W124 E,CE,D,TD Class 2 02-02-2007 10:14 AM
    Seat belt guage Off-Topic 0 11-03-2006 06:57 PM
    Seat Belt jammed/stuck in ML270 Darren_E W163 M-Class 6 10-20-2006 03:21 AM
    seat belt monicaE320 W124 E,CE,D,TD Class 2 04-10-2006 11:21 AM
    Seat Belt Help jele826 W210 E-Class 0 09-19-2005 01:53 PM
