1992 500SL Hardtop, Roll bar & ASR - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 01-11-2007, 02:51 PM Thread Starter
ogn
ogn's Avatar
Date registered: Jan 2007
Vehicle: R129 SL500 (98,97,95,92), W124 (E500&320 93Cabriolet)R107,Toyota Landcruiser2010, Nissan Murano2015,
Hi everyone i have 500sl 92Mdl. my ASR light is alwys on and the Rollbar is coming up by it self when im driving for very short distance and my i cannot release my Hardtop automaticly(just manualy) but i can lock thae hard top automaticly, the Softop is working perfecly, Pls. advice.
FYI. i have no idea about the sockets&how to read the codes and reset the computer can somone explane that ffor me and i will be thankfull for that.
many thanks on advance.
ogn is offline
post #2 of 4 (permalink) Old 01-14-2007, 10:14 AM
Date registered: Jan 2004
Vehicle: '03 SL500, '91 300SL, '91 500SL, '00 S500, '96 C220
Quoted: 149 Post(s)
Originally Posted by ogn
my ASR light is alwys on...
If it comes on while driving, the ABS light in the cluster is out, and the car operates normally (not "Limp" mode), then there is likely a problem with the ASR hardware. Troubleshooting this requires special test equipment. If you would rather not go to the expense of fixing this but find the light annoying, you can, of course, just simply pull the cluster out and remove the bulb.
...the Rollbar is coming up by it self when im driving for very short distance...
This could be a faulty roll bar control module, or one of the limit switches on the rear suspension control arms may be faulty or out of adjustment. I would determine which by short-circuiting the limit switches with a wire or paper clip, drive the car, and see if the problem goes away. Remove the cable from the connector shown in the picture and jumper its terminals. There may be several small connectors in that area -- I don't remember. If there is, look for one labeled "C".
...i cannot release my Hardtop automaticly(just manualy) but i can lock thae hard top automaticly, the Softop is working perfecly, Pls. advice.
Reading/erasing/re-reading codes for the top controller may identify this problem. If it doesn't, I suggest checking the state of all the limit switch inputs to the controller when the hard top is in place, as one of them is probably giving a false signal. The procedure for reading codes is explained here: http://www.benzworld.org/forums/r129...-pre-94-a.html. Since your car is made before '94, you won't need an LED to see the electrical pulses that output a code.
bobterry99 is offline
post #3 of 4 (permalink) Old 01-14-2007, 11:34 AM Thread Starter
ogn
ogn's Avatar
Dear bobterry99: Thanks a lot for your help i will tray this way as soon as possible once i'll get my car runing again because i face a small problem today i had change the radiator 2 days ago and unphortunitkly i broke the small pipe on the top of the radiator, i replace the old one again till i find out some solution to repair the broken pipe, after i reinstall the old one the car start overheating again and i dont know why mybe the water pump or the thermostat... so just give me couple of days, by the way do you know any way to repair the broken pipe coz the one is broken as well and i had to glue it but still to have a new one for 2 days only it's really depressing....
once again thanks for kind assist.
ogn is offline
post #4 of 4 (permalink) Old 01-15-2007, 12:51 AM Thread Starter
ogn
ogn's Avatar
Dear Bob:
If it's possible to send me theThe diagnostic socket The diagnostic socket (each one foe what and what does so i will have complete check on the car and where is the ASR hardware located (if you can attche a photo so you make it more easyer for me and i'll be thankfull for that.
ogn is offline
    1993 500SL roll bar malfunction Pavonman R129 SL-Class 3 03-14-2009 10:53 PM
    1992 500SL ASR Problem chipstone R129 SL-Class 10 02-16-2007 12:58 PM
    1991 500SL roll bar slow going down mikebrou R129 SL-Class 1 01-08-2007 08:47 AM
    1990 500SL roll bar is stuck down! Chris Souch R129 SL-Class 12 08-20-2006 04:44 AM
    ASR/ABS/roll bar lights all came on! firstkill R129 SL-Class 1 07-26-2004 05:43 PM
