722.6 trans A/T Plug Adapter (Conductor Plate Connector) transmission leak - Mercedes-Benz Forum
post #1 of 53 (permalink) Old 12-15-2006, 04:53 PM Thread Starter
Moving On
lynns's Avatar
Date registered: Jul 2006
Vehicle: Y2K SL500 Silver
Quoted: 9 Post(s)
My wife noticed a couple of quarter size drops of oil on the garage floor passenger side. The first INDY I went told me that I needed to relplace the "electrical conductor plate" within the transmission at $675-$750 US.
The next INDY I went to showed me that I needed to replace the "A/T Plug Adapter"(p/n 1402700250), $15.00 plus a small amount of A/T fluid at a total cost of $150 US. I told him to go ahead and do it. Note: you want to wait till the exhaust cools down before you put your hand into this area otherwise you may burn yourself.
Afterwards he showed me the part and explained that the O-ring's can go bad and not only allow a small amount of oil to the ground but A/T oil can go up the electrical cable to the transmission control module (TCM) and damage it. So it is a smart thing to get addressed ASAP. This 2000 car had 25K miles.
NEW p/n 2035400253 - A/T Plug Adapter (Conductor Plate Connector) - MSRP $14.50
OLD p/n 1402700250 - A/T Plug Adapter (Conductor Plate Connector) - MSRP $8.50
"It'is held by a bolt centered in the connector. This is after pulling out the actual electric plug. The 7mm connector bolt is attached to the housing so there's no risk of dropping it. In other words, the new part comes with the bolt and makes it very easy to figure out once you've bought the new part."
Please read Transmission Fluid Leak: Connector?
Please see the attached TSB - Technical Service Bulletin
Auto Trans - 722.6 Oil Leaks From Electrical Connection _ T-B-27.00/48e _ 19-Jan-07
Please see http://www.europeantransmissions.com...ages/722.6.gif
ID:	109149   Click image for larger version
lynns is offline
post #2 of 53 (permalink) Old 04-27-2007, 04:06 PM
FLC2006's Avatar
Date registered: Jun 2006
Vehicle: 1997 SL600 AMG Sport, 05 Golf 2.0GTDI, 92 500SL,98 BMW540i Sport, GTO TT 94 & 96,91 TVR 450SE R.I.P,
Originally Posted by lynns
My wife noticed a couple of quarter size drops of oil on the garage floor. The first INDY I went told me that I needed to relplace the "electrical conductor plate" within the transmission at $675-$750 US.
The next INDY I went to showed me that I needed to replace the "A/T Plug adapter"(p/n 1402700250), $13.00 plus a small amout of A/T oil at a total cost of $150 US. I told him to go ahead and do it.
Afterwards he showed me the part and explained that the O-ring goes bad and not only allows small amounts of oil to the ground but A/T oil can go up the electrical cable to the ECU and damage it. So it is a smart thing to get addressed ASAP. This Y2K car had 25K miles.
Hey Lynn’s
How did you get on with your gearbox? Did you manage to replace the A/T adaptor as described in your post and make good of all issues.
I notice also you have reached Veteran status inside of 10 months, congratulations on that.
A true asset to the Club.
Regards FLC2006
Mercedes AMG SL600 SPORT (Rare:Aquamarine blue) 6.0-Litre–V12-48v-Quad Cam Engine, AMG Exhaust, Xenon Headlights, Panoramic Glass Roof.
FLC2006 is offline
post #3 of 53 (permalink) Old 04-27-2007, 05:31 PM Thread Starter
Moving On
lynns's Avatar
Quoted: 9 Post(s)
Originally Posted by FLC2006
Hey Lynn’s
Regards FLC2006
Thanks for the kind words.
Yes, the A/T plug adaptor has been replaced with the p/n stated above and no more minor leakage.
lynns is offline
post #4 of 53 (permalink) Old 04-27-2007, 06:55 PM
FLC2006's Avatar
Yes, the A/T plug adaptor O-Ring has been replaced with the p/n stated above and no more minor leakage.
How's that beautiful metallic car of yours doing? How many kilometers does she have at this time?
Hi Lynn
I have covered just over 44,000 miles now, man I love these cars.
FLC2006 is offline
post #5 of 53 (permalink) Old 04-27-2007, 09:31 PM Thread Starter
Moving On
lynns's Avatar
Quoted: 9 Post(s)
Hi Lynn
With only 1,164 SL600's made Worldwide in 1997 my guess is that you have a one of kind in the UK.
http://www.benzworld.org/forums/2247078-post2.html
lynns is offline
post #6 of 53 (permalink) Old 12-30-2007, 06:31 PM
Date registered: Feb 2006
Vehicle: 2001-W210-CAPRI METALIC BLUE-/ 2002-W210 E300D
Location: Los Angeles, Ca, Aberdeen Scotland, Lawrence Ks.
Cool you ARE da man, ya know!
THX
B
The finest example of automobile engineering in the world
Floats like a CADI
Stings like a BMR
Stingy as a Prius
and.... all Mercedes Benz.
MRBSMITH is offline
post #7 of 53 (permalink) Old 02-13-2009, 02:30 PM
slninja's Avatar
Date registered: Feb 2009
Vehicle: 1995 SL320 R129
Send a message via AIM to slninja Send a message via MSN to slninja
Hey, I know this post has been done for quite a while now. But I was wondering if anyone knew where I can get my hands on those two o-rings mentioned above? My 95 SL320 is leaking, seems as if its the same issue. The ATF spreads underneath my car as I'm driving and when my pan/exhaust get hot it starts smoking in and outside of the car. (Freaked me out the first time it happened! Haha)
But yeah, any help would be very appreciated!
P.S. newly registered, but I've been reading this forum for years! Love it!
slninja is offline
post #8 of 53 (permalink) Old 02-13-2009, 02:34 PM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
The O-rings are not separately available, buy the new and improved connector noted above and it comes with them. There is a DIY in the W210 forum help stickies on this replacement, I did it myself in about 45 minutes from time I got out the jack until the time I was washing my hands. Not difficult but the higher you raise the front end, the less fluid will leak out while you have the connector out.
Take care and enjoy the ride,
Greg
Check Codes is offline
post #9 of 53 (permalink) Old 02-13-2009, 02:38 PM
RKH
RKH's Avatar
Date registered: Apr 2008
Vehicle: Departed 1998 SL500 (and the Pano is in Bogota)
Quoted: 482 Post(s)
Well, LynnS had provided the P/N, just take that to the Dealer and ask for it. Or get them online, but I have a feeling the Dealer would be cheaper when you don't have to pay shipping.
RKH is offline
post #10 of 53 (permalink) Old 02-13-2009, 02:48 PM
slninja's Avatar
I tried looking up the part numbers online before posting. Unfortunately, the only website that had them is from New Zealand. The shipping is 5x the price of the actual O-ring.
Anyway, the reason I want to know the sizes before I go to a dealer is because I have a stack load of O-rings that may fit and rather use instead.
Thanks!
slninja is offline
How are these related: 1. Conductor Plate 2. A/T Adapter 3. Control Module. Pancho C208/A208 CLK-Class 6 11-24-2011 09:45 PM
transmission electric connector adapter plug thingy--why do they fail? Elvis_Presley W210 E-Class 26 11-04-2011 08:28 PM
Location of conductor plate on trans??? klove0972 W220 S-Class 2 07-12-2011 11:43 AM
conductor plate an electrical connector Updated? nrphlly C208/A208 CLK-Class 2 05-05-2011 08:33 PM
Trans conductor plate cindyj578 W202 C-Class 2 03-02-2009 10:25 AM
