» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Roadster Forums > R129 SL Class
Old 11-23-2006, 12:06 PM   #1 (permalink)
Date registered: Aug 2006
Vehicle: 1996 R129 SL500
Dead battery
Happy Thanksgiving to all!
One of my biggest fears was leaving the lights on and killing the battery. Well, I went and did it. I recharged the battery with a charger.
I resync'd the windows, inserted the code for the radio, but now my attenna is not going up or down even though the I hear the motor spinning. The other thing which is interesting is my convertible top button light is on steady and the up arrow lights in the roll bar switch on the dash is glowing steady as well. I have the hardtop on and obviously because of this situation it is not releasing the hardtop from the locked position.
Is there something I am supposed to do to resync everything or did I mess something up?
John
____________________________________________
1996 129 500
Madison, CT
jfmct is offline   Reply With Quote
Old 11-24-2006, 06:57 AM   #2 (permalink)
Carlo$'s Avatar
Date registered: Sep 2003
Vehicle: 97 SL500
i have heard of similar problems, search. cause of what i read a long time ago when my batt died i did not even try to recharge or jump, i just went out and bought a brand new one (interstate battery). so far so good it all works.
as for your antenna i think is just a coincidence that it doesnt work, i dont believe its related.
read this: http://www.cardomain.com/ride/262575/34
http://xrl.us/benz1
Carlo$ is offline   Reply With Quote
Old 11-24-2006, 10:47 PM   #3 (permalink)
Date registered: Jan 2004
Vehicle: SL500, 300SL, 500SL
I agree with Carlos about the antenna. Regarding the top, a fault code is probably set within the controller that is inhibiting operation. The only documented procedure for resetting the code is to use an advanced scan tool that would typically be had only by a Mercedes service shop.
bobterry99 is offline   Reply With Quote
Old 11-25-2006, 06:59 AM   #4 (permalink)
msbarsi's Avatar
Vehicle: 2000 Obsidian Black Metallic Mercedes SL 320 V6
Hi people, I just wanted to know if you can confirm the lenght of the antenna mast while fully extended.
Thanks in advance.
Cheers.
msbarsi is offline   Reply With Quote
Old 11-26-2006, 06:40 AM   #5 (permalink)
StatManSL's Avatar
Date registered: Sep 2005
Vehicle: 1997 SL 320
Carlos....I'm thinking of getting an Interstate battery as well before the Winter sets in...The correct number is "MTP (Megatron Plus) - 93".....Correct??
TIA
Tom
StatManSL is offline   Reply With Quote
Old 12-11-2006, 01:20 PM   #6 (permalink)
Carlo$'s Avatar
Vehicle: 97 SL500
i dont know the correct number, i took the car to the mechanic and he replaced it. i'll try to find out the part number.
Old 12-12-2006, 04:09 AM   #7 (permalink)
Date registered: Jun 2005
Vehicle: r129 SL500
Antenna sticking can often be fixed by giving it a helping hand (pull firmly) whilst
the motor is running in the "up" mode. When released, even an inch or so, squirt WD40 or similar down inside and continue attempting to operate. Antenna often stick because they are dirty.
The easiest way to charge your battery is via the Cigar lighter using an adapter.
I use a battery conditioner all the time, this has the advantage of not requiring any attention, even if you dont run your car for months, it will still start first time and no loss of computer memories
sligogolfer is offline   Reply With Quote
Old 12-12-2006, 06:31 AM   #8 (permalink)
Carlo$'s Avatar
Vehicle: 97 SL500
here is a charger for less than 10 usd.
http://www.harborfreight.com/cpi/cta...emnumber=42292
Old 12-12-2006, 10:02 AM   #9 (permalink)
Date registered: Feb 2005
Vehicle: '03 CL500,& '07 GL450
Interstate battery
On my 1999 SL500 i replaced the original MB battery with an:
Interstate #00MTP-93 battery. 850CCA., 1065 CA., 155 RC(min), & a 85month warranty.
reddog is offline   Reply With Quote
Old 12-12-2006, 10:41 AM   #10 (permalink)
Vehicle: 2000 SL500 Mineral Green
Consumer Reports mag does rate Interstate batteries very highly, but I've been happy with mine.
Battery tenders are an excellent idea. Great care must be taken with chargers though. While my 95 SL320 was at a body shop for collision repair the battery ran down. The charger they used blew some kind of computer located in the lower part of the engine compartment. Repair cost $1500.
herb is offline   Reply With Quote
If you have a dead battery? articdub W220 S-Class 15 12-02-2007 04:33 PM
Please help Battery Dead dimit W208 CLK Class 5 09-08-2006 01:20 AM
Dead battery mikeraj W202 C-Class 13 04-10-2006 03:24 PM
dead battery? bwolfe W211 E55 AMG, E63 AMG 0 05-20-2005 11:17 PM
New Battery Dead twenty3sky W123 E,CE,D,CD,TD,TE Class 22 12-09-2003 07:21 PM
