» Site Navigation
» Other Sites
Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Roadster Forums > R129 SL Class
Old 08-09-2006, 09:02 AM   #1 (permalink)
lynns's Avatar
Date registered: Jul 2006
Vehicle: MY00 SL500
door check strap / stay
I have a 2000 SL500 that I just purchased with 20K miles. Both doors made a sound that was very annoying for what I believe is uncalled for in a car of this caliber so I had both Door Check Straps replaced by an Indy for $225 labor + $53 parts = $278.
As far as I am concerned it was well worth the cost. Both doors are like new. It appears that a ball bearing like part in the door stay goes bad so no amount of lubricant will fix it. In fact I tried WD40 and it made it worse. The Indy showed me the used part and it had plenty of grease.
Please read http://www.benzworld.org/forums/r129...tallation.html and DIY-Replacing Door Checks
Regards, Lynn
MY00 SL500 triple black Sport
MY89 560SL triple blue SOLD
MY88 560SL white on tan SOLD
lynns is offline   Reply With Quote
Old 01-04-2008, 01:29 PM   #2 (permalink)
lynns's Avatar
Vehicle: MY00 SL500
You can get 'DOOR CHECK STRAP' p/n 1297200116 for $21.25 at Parts.com
Old 01-11-2008, 11:36 AM   #3 (permalink)
jaybro's Avatar
Date registered: Feb 2003
Vehicle: 1999 C-280. & SL500
Door Check/Stay
Lynns,
I may have discovered the mystery of the noisey door check. "Lubricated by anal retentive R-129 owners". I removed the offending part, waiting for delivery of new parts. I disassembled the door check, cleaned it, removed all the old lube, relubed and installed it in the door, same old, same old, noisey as ever. Took it apart again, no serious signs of wear (it is Mercedes) disassembled, removed all the lube, put it back togeather dry, put it in the door, QUIET, no noise works like new. Maybe we are oiling parts that should not be oiled, forget the WD-40 take it out and soak in a wax/grease remover. Hope I am correct, I'll leave the cleaned up part in the door and see how it goes. One final note don,t try taking the door check apart unless you have a bench vice to compress the springs to get it reassembled
jaybro
jaybro is offline   Reply With Quote
Old 01-11-2008, 12:44 PM   #4 (permalink)
lynns's Avatar
Vehicle: MY00 SL500
Originally Posted by jaybro View Post
Lynns,
I'm glad you brought this up. Whenever I tried to lubricate my check straps with WD-40 it seemed to make it worse just as you found. It wasn't until they were replaced that my problem went away. I looked at the old door strap quickly and thought it was the ball bearing part that wore out and needed replacing but maybe you found something else.
Please keep us posted.
BTW, when I was test driving SL's prior to purchase I found that six of six cars had a noisy driver side door check strap in addition to the one I purchased.
Metal split around check strap / Door removal wmedia W140 S-Class 5 09-17-2005 08:01 AM
Door Strap? Where can I find one? Stickman W124 E,CE,D,TD Class 3 07-27-2005 10:01 AM
Any help removing pin holding door check strap? I want to replace a loudly creaking check. Brett San Diego W140 S-Class 4 08-25-2004 01:57 PM
Door Strap Repair Judas W140 S-Class 3 02-04-2004 06:27 PM
Creaky rear door, Check strap replacement needed?.. shrimpton W126 S,SE,SEC,SEL,SD,SDL Class 2 09-14-2003 07:50 PM
