Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Roadster Forums > R129 SL Class
Old 05-24-2006, 07:38 AM   #1 (permalink)
hifeverz's Avatar
Vehicle: 1990 300SL, 2004 E320
Send a message via Yahoo to hifeverz
Unhappy ## FAILED SMOG again ##
1990 300SL 151k miles
Fixes: New spark plugs, new wires, new air filter
Prior to smog test drove car approx. 30miles at hiway speed.
I've failed the smog again. The results are as follows:
HC(ppm)
15mph: MAX=102, Measured=130 > FAILED
25mph: MAX=77, Measured=96 > FAILED
CO(%)
15mph: MAX=0.68, Measured=0.07 > PASSED
25mph: MAX=0.55, Measured=0.09 > PASSED
NO(ppm)
15mph: MAX=748, Measured=141 > PASSED
25mph: MAX=687, Measured=113 > PASSED
Any simple DIY suggestions?? What can I do before I retest?? Could it be O2 sensor?? Fuel enrichment adjustment? OR????
I need your expert help out there before I get to a shop jock who'll charge a small fortune.
Thanks,
Hz
hifeverz is offline   Reply With Quote
Old 05-24-2006, 08:36 AM   #2 (permalink)
lnguyenh's Avatar
Date registered: Jan 2004
Vehicle: SL500, S420
your engine failed on the third cycle which is the combustion. Your combustion is likely incomplete. This could be the result of many things like piston rings (leaks), spark plugs, gas octane ... causing the engine misfired.
When the fuel is not burn completely, it produces high HC.
Oh, also look for intake air system (for leaking).
lnguyenh is offline   Reply With Quote
