» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Roadster Forums > R129 SL Class
Old 04-14-2006, 02:10 PM   #11 (permalink)
Date registered: Jan 2006
Vehicle: 1995 SL500
RE: The 100th Convertible Top Leak Post
Well listen to this horror story. I had a slight drip over the drivers side visor. took it into the shop to be fixed, they suggested replacing both of them in the front. so I did, when they tested the system after that , the higher pressure now in the system because the leaks were fixed blew out another one in the back. I just got a call that the larger pistons are also now seaping, so I have a bill so far for $1100+ for the smaller one, and the larger ones are $700 each,. looks like I am in for a $2500 to $3000 bill. the bad news is they can not find the large ones and my car is torn apart. And they just closed for the Easter weekend. No idea when the car will be done and no idea what it will cost me. this is the nightmare I was trying to aviod.. And of course the weather is perfect this weekend in the 80's and I am driving my daughters old jetta..
Steve1g is offline   Reply With Quote
Old 04-14-2006, 04:59 PM   #12 (permalink)
Date registered: Aug 2005
The top is a horror story no matter how you go about it.
I miss my Mazda RX7 that had an electrical top and managed to go up and latch with just a little hassle for 20 years without failure.
jef_1_f is offline   Reply With Quote
Old 04-14-2006, 08:59 PM   #13 (permalink)
Date registered: Dec 2004
Vehicle: 1990 500SL
Send a message via AIM to 90-500SL Send a message via Yahoo to 90-500SL
yup. it seems if you replace one, it kills another.... its just a domino effect... mine were ALL replaced in 1996. and im just now replacing them all again. i only have two left to replace....... if you take it into Mercedes-benz dealer. they recommend replacing all at once to save on labor.
oh and if you have a early SL, and are still on the original hydralics, expect to replace a Few latch assembly's as well as the hydraulic cylinders.... the small cylinders (latch the rear windows, and latch the soft top boot cover) have been updated with a new part, and are discontinued. the new design DOES NOT fit in the old latch assembly... part number 129 800 00 72 is no longer a valid part number.
1990 500SL....
143,563 miles and still counting... well not anymore.. dead Odometer.....
Check Out my Gallery!
90-500SL is offline   Reply With Quote
Old 04-29-2006, 09:32 PM   #14 (permalink)
Finally got the job done. It's a 30 minute to one hour job if you have all of the tools. I didn't.
Along with the regular stuff, You will need a # 40 and # 30 torx (just buy a set) and a 7mm open end wrench that is very thin.
I bought one at Ace hardware that worked but it would work better if I hit with a grinder or dremel and took about a mm off.
My recomendations?
Buy the little plugs for the hydraulic lines. You'll save time on cleaning up fluid.
Top is working 100% now and I am praying to the hydraulic convertible top gods to not blow out any other cylinders for some time.
Old 05-04-2006, 10:56 AM   #15 (permalink)
Date registered: Sep 2004
Vehicle: 1998 mercedes sl500
i fixed the hydrulic leak in my 98 sl500 by replacing the MB fluid with NO LEAK BRAND power steering fluid last summer and still no leak, it appear the seal get hard and leak , NO LEAK BRAND power steering fluid soften the seal stops the leak i paid MB dealer 650.00 the first time it happened . this time it cost 6.00 . you will need to add no leak brand power steering fluid to the reservoir in the trunk and allow a couple of days to work its way through the system. good luck
tennis1 is offline   Reply With Quote
Old 05-07-2006, 01:49 AM   #16 (permalink)
Tennis...
Is this it?
http://wwww.shop.com/product/FLUID_P...AK/9724537.htm
Old 05-08-2006, 07:36 AM   #17 (permalink)
that it ..
yes , thats it, i took out enough fluid from my resoviour to add all of the NO LEAK power steering fluid it took about a week to work its way through but when it did it just stoped and that was last summer.
Old 07-06-2006, 04:53 AM   #18 (permalink)
detailas's Avatar
Date registered: Jul 2005
Vehicle: SL500 03, GR.CHEROKEE LTD 01
Send a message via MSN to detailas
Originally Posted by TheVpwr
I have most of the hydraulic cil. for the top.
Front 129 800 1672 (two) $140.
If you let me know the part # of the one on the back I might have it as well.
Hey Vpwr, facing pillar leak as well... I would appreciate your advising me if you have part no. 129 800 0774 (left) + 129 800 0874 (right) and cost for these.
Thanks a lot
George (detailas@yahoo.com)
detailas is offline   Reply With Quote
Old 07-06-2006, 11:11 AM   #19 (permalink)
detailas's Avatar
Please disregard my previous thread - i will be needing the 129 800 1672 (two) after all - do you still have them?
Appreciate yr reply.
Regards
George
Old 07-06-2006, 06:47 PM   #20 (permalink)
Date registered: Apr 2006
there is a shop in my city fix any hyd leak by making a new seals . he did fix mine for only about 20 us dollars and it was a very bad leak near to the rear wheel. it is very simple they can make any rubber seal and doesn't cost alot.no need to change the piston.
feras is offline   Reply With Quote
