» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Roadster Forums > R129 SL Class
Old 08-30-2005, 10:47 AM   #1 (permalink)
Date registered: Dec 2004
Vehicle: 1990 500SL
Send a message via AIM to 90-500SL Send a message via Yahoo to 90-500SL
Leaking Hydraulic Cylinders
i am looking for anyone of you who still have your leaking cylinders laying around from when you replaced them. i've figured out how to rebuild them, and i lost one of the main rings that hold the whole thing together. if anyone has one laying around.... i NEED it! HELP!
Devon
1990 500SL....
143,563 miles and still counting... well not anymore.. dead Odometer.....
Check Out my Gallery!
90-500SL is offline   Reply With Quote
Old 07-14-2006, 02:14 PM   #2 (permalink)
Date registered: Jun 2006
Vehicle: 1997 SL500
Rebuilding Hydraulic Cylinders (pt.#1298001672)
I too have taken (1) apart and found the main culprit to be the inside "wiper ring". I have not been able to find a source for this ring. If you are still around, where did you find a source for this ring?
The "spring " clip which holds it all together I believe to be a fairly generic item which should be available from an automotive parts source.
JohnDB is offline   Reply With Quote
Old 07-14-2006, 02:53 PM   #3 (permalink)
SunGuy61's Avatar
Vehicle: 1987 560SL Gone but not forgotten! & 1999 SL500 For Now
Send a message via AIM to SunGuy61
Let's keep this thread alive! I've got two (2) of these cylinders I want to rebuild but first want to nail down exactly which rings or seals I need to have on hand before diving into these things. You'd think some genius would come up with a rebuild 'kit' with $5 worth of parts and sell 'em for $50!
Bob
SunGuy61 is offline   Reply With Quote
Old 07-15-2006, 01:10 AM   #4 (permalink)
Date registered: Apr 2005
Vehicle: 97 e320, 94 sl320, 99 mustang, 90 & 91 300zx twin turbo
come on guys, we need to learn how to rebuilt these cylinders ourself, if anybody have done this procedure, please post DIY
97 E320 GREY
94 SL320 BLACK
95 E320-SMOKE SILVER-GONE
93 190E-BLACK-GONE
91 190E-BURGUNDY-GONE
91 190E-WHITE-GONE
99 MUSTANG-WHITE
95 3000GT BLACK-RED-GONE
91 300ZX TWIN TURBO-RED-GONE
90 300ZX TWIN TURBO-RED-GONE
88 DODGE DAYTONA SHELBY Z-RED-GONE
92 JETTA-BEIGE
interior-magic is offline   Reply With Quote
Old 07-15-2006, 11:06 AM   #5 (permalink)
SunGuy61's Avatar
I found this old post from 2004 at the MB DIY site. The spec's for the seals are in the post, and I ping'd Dennis to see if he's still rebuilding these things. FYI
Bob
R129 Hydraulic top cylinders
Hi folks, I thought some of you may be interested that I've found a way to rebuild the top cylinders with the 6mm rods. I have just finished rebuilding the tonneau cover cylinders and I will be removing the rear latch cylinders tonight. (all of my cylinders are leaking)
The repair is fairly simple. The bad thing is that Mercedes used a bastard size piston rod seal that I haven't been able to find without being custom made. I did find a very close match at http://www.epm.com, but I did have to machine the cap that holds the seal from 13mm to 14mm. I'm a machinist so machining the cap wasn't a problem.
If anyone is interested I'll have some seals leftover ( $75 minimum order at epm!!!). I can either sell just the seal for $4 or if you send me your used cylinder I'll install the new seal, new o-ring on the seal cap, and polish the piston rod for $30 plus shipping. If there's enough interest I'll purchase more seals.
Next I'll be tackling the main top cylinders.
seal size is 6mm ID x 14mm OD x 5.7mm thick U-CUP Polyurethane Rod Seal
Dennis Ficken
Olathe, Ks
'91 300SL
'88 300E
Old 07-30-2006, 01:56 PM   #6 (permalink)
Did you find out if Dennis still fix the cylinders?
Old 09-10-2006, 10:16 PM   #7 (permalink)
Date registered: Sep 2006
Vehicle: 1995 Mercedes Benz 500 SL Convertable Coupe
Send a message via Yahoo to Flamenco2005
Rebuilt Top cylinders.
Bob
Dennis Ficken
Olathe, Ks
'91 300SL
'88 300E
Would the same thing apply for 91 Sl500 Roadster? Also if you already have some cylinders done I'll trade you a Leaky one for a good one and pay you the $30.00 and you keep the leaky one to fix for someone else.
Sounds like a business idea to me?!
Flamenco2005 is offline   Reply With Quote
Old 09-11-2006, 09:24 AM   #8 (permalink)
SunGuy61's Avatar
flamenco, Dennis turns these around in a couple days after receipt. Just contact him for particulars.
Bob
Old 09-13-2006, 10:46 AM   #9 (permalink)
Thanks, Shipping them out today.
Old 09-13-2006, 11:31 AM   #10 (permalink)
alydon's Avatar
Date registered: Mar 2004
Vehicle: 95 E420, 96 SL320, 61 220SEb
Can you post Dennis' contact particulars (e-mail address, phone #, mailing address) so we can make this thread a sticky on this site?
Al Lydon
96 SL320
alydon is offline   Reply With Quote
