» Site Navigation
» Other Sites
Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Roadster Forums > R129 SL Class
Old 11-04-2004, 02:39 PM   #1 (permalink)
Date registered: Nov 2004
'03 SL500 wheels on R129
Does anyone knows if the 20003 SL5000 wheels fit a 19996 SL500?
one dealer told yes, another one told me no and the shop here in delaware the specialize in MB wheels told me the the bolts on 2003 are way bigger(thick) than the bolts of R129 and won't fit..
Thanks
Petros
petrosvr4 is offline   Reply With Quote
Old 11-04-2004, 09:45 PM   #2 (permalink)
JimP's Avatar
Date registered: May 2003
Vehicle: 97' SL600 Sport Panoramic
RE: '03 SL500 wheels on R129
Check in the tire forum. I've hear they have different size lug holes and the offset is different.
Nobody Poses with their toaster!
1997 SL600
1990 300e
1988 924s
1998 Durango
1993 740i
JimP is offline   Reply With Quote
Old 11-05-2004, 07:31 AM   #3 (permalink)
EuroCoupe's Avatar
Date registered: Aug 2003
Vehicle: W126C AMG 6.0
A guy on my street has them on his R129 500SL and I've seen them on 3 other R129 SL's here. They have to be able to work somehow.
Mike
Old School AMG Junkee
W126C- 6.0L AMG 32v- SOLD!!!
W163
W124
EuroCoupe is offline   Reply With Quote
Old 11-05-2004, 07:44 AM   #4 (permalink)
lnguyenh's Avatar
Date registered: Jan 2004
Vehicle: SL500, S420
The bolts you can work on to make it fit. New wheels has less offset which will stick out a little too much (around 1/2 of an in.); hence, it will "hurt" your car later
To sum up: it will fit but it is a bad idea.
lnguyenh is offline   Reply With Quote
Old 11-05-2004, 05:15 PM   #5 (permalink)
EuroCoupe's Avatar
The R230 wheels have offsets of 33 and 30. Those are fine for the R129 and don't know why they would "hurt it." The AMG 18" R129 sport wheels have offsets of 25 and 23 and the 17" AMG 3-peice were 18 and 17. Factory offset on the R129 is 34 so these should be fine. By the way, there is a black R129 500SL in the parking lot of my office with the R230 AMG wheels as well. It can be done and I think they fill out the wheel wells nicely. The 16 and 17" factory wheels with 34 offset leave too much fender gap in my opinion.
Old 11-05-2004, 08:03 PM   #6 (permalink)
BenzWorld W210 Host
Storm.'s Avatar
Date registered: Jul 2004
Vehicle: SL, CLK & 5E's
The Wheels (specially the turbines) look HOT on the 129. Bolt holes are 2-3mm bigger than the ones on the R129 rims, but can be filled with tiny spacers on the bolts.
Storm. is offline   Reply With Quote
Old 11-10-2004, 06:06 PM   #7 (permalink)
Date registered: Mar 2004
Vehicle: 95 E420, 96 SL320, 61 220SEb
I am also interested in this topic. The R230 SL seven spoke wheels are 8.5x17 ET35 vs my stock 8x16 ET34 wheels. Should be a perfect fit. Issue remains the lug bolts. Can someone provide definitive guidance on 12mm lugs on wheels meant for 14mm lugs. What about lug length?
Tks,
Al Lydon
alydon is offline   Reply With Quote
Old 11-11-2004, 10:06 AM   #8 (permalink)
Can u tell where to find these spacers? Anythin else you think that i should need?
Thanks
Petros
Old 12-16-2004, 08:13 AM   #9 (permalink)
SYC
Date registered: Dec 2004
Vehicle: '91 SL500
hi there, i'm trying to do the same... does someone know where i can get the spacers for this? any advice???
thx.
SYC is offline   Reply With Quote
Old 12-16-2004, 11:51 AM   #10 (permalink)
BenzWorld W210 Host
Storm.'s Avatar
You can have any metal shop machine you a set. I made my own. (after a bit of trial and error I got 20 perfect bolts and spacers).
