Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Roadster Forums > R129 SL Class
View Poll Results:
0%
Voters: 0. You may not vote on this poll
Old 11-01-2004, 02:36 PM   #1 (permalink)
Date registered: Nov 2004
Soft Top Hydraulic Leak 1998
I have a 1998 SL500. Recently I opened the soft top to see hydraulic fluid leaking from the corners of the top of the windshield. Probably a cracked line. Is there an easy way to fix this or is it a job for an expert.
Thanks
elliotlewis is offline   Reply With Quote
Old 11-01-2004, 02:57 PM   #2 (permalink)
SL60 ///AMG's Avatar
Date registered: Oct 2004
Vehicle: SL60 ///AMG
RE: Soft Top Hydraulic Leak 1998
I think you can find something in this thread.
http://forums.mbnz.org/forums/forums/thread-view.asp?tid=1177161&posts=23&hl=Hydraulic+Leak
/HĂĄkan
<p><a href="http://r129.info"><img border="0" src="http://www.r129.info/Onwebb/R129/Random/bild.jpg"></a></p><small>No supercharge, no turbo. Just real power. Luke says -A <b> obsidian black </b> SL60 ///AMG -96 Rocket edition. That´s his car, and the force is with him! </small>
SL60 ///AMG is offline   Reply With Quote
Old 11-01-2004, 03:46 PM   #3 (permalink)
Thank you. I guess I will not know if it is the latch or the hydraulic until I open the lid. That part sounds easy enough. Do you know if you can buy just the hydraulic part or do you have to buy the latch(s)?
Old 11-01-2004, 05:24 PM   #4 (permalink)
I can look in my EPC, but I´m sure that somebody already know the answer. If you don´t recive any answer in 16 hours, I look into the EPC for you. If I don´t, please remind me in a note to hano@r129.info
/HĂĄkan
Old 11-02-2004, 11:04 AM   #5 (permalink)
elliotlewis - 11/2/2004 12:46 AM
Well, the hydralic lines is sold separate and also the locks. For my car (1996) the partnumber (number 5 in picture # 2) for the locks is A1298000774 (LEFT) and A1298000874 (RIGHT). You can see them in picture I attached.
Old 11-07-2004, 03:45 PM   #6 (permalink)
Vehicle: 94sl-600
What is it about the MBZ top hydraulics that make them such a frequent leaker? Is it the wrong oil? Wrong seal materials? This is inexcusable. There is no earthly reason why these repeated seal failures should happen. In the 23 years I maintained my Citroen SM I NEVER had to replace a hydraulic seal. I did have to change 2 dust boots on the rear suspension, and the accumulators twice.
I suspect the oil and seals are incompatible. Maybe we should be using Nissan Active Suspension oil ($16/l). Their active suspension cars don't leak either.
kebowers is offline   Reply With Quote
Old 11-10-2004, 05:19 AM   #7 (permalink)
lnguyenh's Avatar
Date registered: Jan 2004
Vehicle: SL500, S420
Good job posting those pics SL 60.
elliotlewis, you can buy the parts at mercedesshop dot com. Just ask for Phil.
1-888-333-4642 or philip@mercedesshop.com
I did it when my top leak. very simple job tho you need to have stars and hex keys.
lnguyenh is offline   Reply With Quote
Old 04-27-2005, 12:34 PM   #8 (permalink)
Date registered: Apr 2005
I just joined the site and wanted to say thank you for all who provided info on this string. i just spoke with phillip (phillip@mercedesshop.com) and have ordered the cylider to replace. 130 v. 1000 at the dealership!
on a somewhat related note - the plastic windows on the back of the softtop have small runners (cracks). is there any other way to repair other than paying 3,000 for a new top?? thanks in advance!
chad.
chagan is offline   Reply With Quote
Old 05-03-2005, 12:10 PM   #9 (permalink)
Date registered: Dec 2003
If your leak was like mine, it's probably the hydraulic cylinders above the windscreen. I was able to buy 2 replacement cylinders online for about $270.00. It took about an hour to replace them...and I'm a real novice. The dealer wanted $1500 to replace them. Let's see....$270 compared to $1500? That's a no brainer.
txferret is offline   Reply With Quote
