» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Roadster Forums > R129 SL Class
Old 09-06-2008, 10:17 AM   #11 (permalink)
Airport66's Avatar
Date registered: Oct 2006
Vehicle: 1992 SL-300
-+ Thanks, I ordered the part $9.99, however $11 shipping and $2 handeling. This top has driven me crazy, I took the entire controller and cleaned and lubricated every electro mechanical relay. Put it back togrther and nothing. Put the top up manually and used the switch just to klatch the windshield and it began working both up and down. Today, nothing. I am trading this thing for a corvette with a manual top!!
Airport66 is offline   Reply With Quote
Old 09-06-2008, 10:26 AM   #12 (permalink)
RKH
RKH's Avatar
Date registered: Apr 2008
Vehicle: 1998 SL500 Panoramic Roof
It may be cheaper to just drive over to buy it from the Dealer. It may cost more but save on shipping. On the other hand, the saving will only buy you 2 gal of gas.
RKH is online now   Reply With Quote
Old 09-06-2008, 10:29 AM   #13 (permalink)
lynns's Avatar
Date registered: Jul 2006
Vehicle: 2000 SL500 Sport
Originally Posted by RKH View Post
The white plastic thing is the fuse puller.
Yes, and I pulled my 'fuse puller' out of the tool set and placed it in the engine compartment fuse box so that I don't have to pull my trunk a part in order to use it.
lynns is offline   Reply With Quote
Old 09-06-2008, 10:32 AM   #14 (permalink)
lynns's Avatar
Quite honestly most dealers don't sell them individually. They will sell you the whole set of tools for $139.00.
Old 09-07-2008, 08:17 AM   #15 (permalink)
aam
aam's Avatar
Date registered: Dec 2004
Vehicle: SL500-500SEL-190E
To whom it may consern.
Well I was doing the rear brakes and tried to put back the wheels I had a hard time
centering them.
The front are easier.
I couldn't find that centering pin tool.
So I went in my garage cut a 1/2 x 4" threaded rod.
We use it in construction to suspend pipes etc, re thread both sides about 1/2" with a 12x1.50 mm, and I made a home made tool.
performanceproducts sells this tool made out of brass for $29
If you need to make one it can be done practically for nothing.
I made two of them just in case I lose one.
Regards.
aam.
aam is offline   Reply With Quote
Old 09-07-2008, 10:07 AM   #16 (permalink)
lynns's Avatar
Yes, and it is one of the tools that comes as a part(far right) of the MB tool kit above.
