1994 SL500 window won't go up. - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 08-20-2004, 08:09 AM Thread Starter
Date registered: Jul 2004
I put my passenger window down last night and when I went to put it up it started and then stopped. I then put it down and it went down. Now it won't move at all. I can hear the motor running but the window does not move. Anyone have any suggestions on what could be wrong and how to go about fixing it.
Thanks[:D]
samtbenz is offline
post #2 of 4 (permalink) Old 08-21-2004, 09:45 AM
BenzWorld W140 Host
zeaq's Avatar
Date registered: Aug 2003
Vehicle: W140 S 320 L & R129 500SL
Quoted: 4 Post(s)
Send a message via MSN to zeaq Send a message via Yahoo to zeaq
RE: 1994 SL500 window won't go up.
Maybe changing the regulator.....My S320 has the same problem as Ur car....I Change the regulator and all problem solve....[:)]
zeaq is offline
post #3 of 4 (permalink) Old 08-23-2004, 03:36 AM
Date registered: Jun 2003
Vehicle: Mercedes 300 SL-24
I had the same problem. I had the window engine opened and cleaned: it has an POM made gear that was filled with rust from the engine cover (maybe it got some moisture).
After that it works ok. Probably you don't need to replace the engine.
Jorge
'91 300 SL-24
AJSM is offline
post #4 of 4 (permalink) Old 08-23-2004, 01:03 PM
Date registered: Aug 2004
Vehicle: 500SL
Send a message via MSN to cbradlea
I recently had the same problem one of the bolts holding the window was lose. That caused my window to go up slow and sometime not close. Tightened the bolt and like magic it worked again.
cbradlea is offline
