Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Roadster Forums > R129 SL Class
Old 04-16-2004, 09:49 AM   #1 (permalink)
robinp's Avatar
Date registered: Feb 2004
Vehicle: 300SL-24V/CLK 200 /Toyota Harrier
seat adjustment
my 91 SL have a problem with the seat adjustments.
Sometimes frt driver seat cannot move forward n backward while all other adjustments are ok .
How can I solve this problem?
robinp is offline   Reply With Quote
Old 04-16-2004, 07:16 PM   #2 (permalink)
JimP's Avatar
Date registered: May 2003
Vehicle: 97' SL600 Sport Panoramic
RE: seat adjustment
It might just be the seat switch. you can try pulling the plug off the back of the switch and using a jumper wire to operate in place of the switch. if you can figure out what pins are what. You can use a meter to determine if the switch is making a circuit when you move it in the desired direction.
Nobody Poses with their toaster!
1997 SL600
1990 300e
1988 924s
1998 Durango
1993 740i
JimP is offline   Reply With Quote
Old 04-18-2004, 11:20 AM   #3 (permalink)
robinp's Avatar
RE: seat adjustment
thanks, I'll try that..
Old 04-18-2004, 10:41 PM   #4 (permalink)
Date registered: Jan 2004
Vehicle: 300SL, SL500
RE: seat adjustment
If the memory positions have different front-back locations stored and the seat responds to these but not the switch, then you can be sure your problem is the switch or its wiring.
bobterry99 is offline   Reply With Quote
