Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Roadster Forums > R129 SL Class
Old 04-15-2004, 07:02 PM   #1 (permalink)
Date registered: Apr 2004
Vehicle: 1992 SL 500
ASR light is on - car safe to drive?
MY ASR light is on - Ive been told that the car may not be safe to drive -- any advise out there ?
thks
RalphAlvarez is offline   Reply With Quote
Old 04-16-2004, 03:13 PM   #2 (permalink)
Date registered: Apr 2003
Vehicle: R129SL
RE: ASR light is on - car safe to drive?
I had the same problem last year. The ASR motors will need to be replaced ($ 1,800 Parts & Labor).
You should be experiencing a decrease in engine power while driving, the transmission may behave erratic, and sometimes the car may die when you come to a complete stop, and you will need to restart. When the ASR system is defective the car is programmed to drive at only ¾ of the engine power (Limp Home Mode). It’s designed to allow you to make home.
You should not drive the car if the system is malfunctioning; it puts a strain on the engine and transmission.
chipstone is offline   Reply With Quote
Old 04-17-2004, 12:27 AM   #3 (permalink)
Date registered: Nov 2003
Vehicle: SL500/1990
Send a message via AIM to desvaux
Hello,
Look at the connectors under the footbrake pedal, it's
possible that these connectors are not very clean, it should be cleaned and
if they are in very bad condition they will have to be changed.
Has soon.
Dave
desvaux is offline   Reply With Quote
