Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Roadster Forums > R/C107 SL/SLC Class
Old 08-08-2003, 02:16 PM   #1 (permalink)
Date registered: Jul 2003
Vehicle: CJ,300SD,SJ,TDIJett
82 380sl - heavy black smoke
Dear Experts,
Our pristine little beauty, '82 380SL, appears to be running a little too rich but I think it's more than that simple.
It smokes black heavily when it's started cold, also smokes bad when it's hot if I rev up the rpms in park or neutral - not that we do this.
We chanaged the injectors, frequency valve, oxygen sensor and prior to that the spark plug wires and plugs.
There's no freon in the a/c system if that makes a difference.
Thanks, Aleks
Aleks is offline   Reply With Quote
Old 08-09-2003, 01:05 AM   #2 (permalink)
heckflosse's Avatar
Possibly worn valves or seals allowing oil to enter the head. As a general rule black s...
As a general rule black smoke is usually oil, blue is fuel and white/clear water.
heckflosse is offline   Reply With Quote
Old 08-11-2003, 01:09 AM   #3 (permalink)
Greg in Oz's Avatar
Vehicle: 350SLC, 500SLC, 300TE, 190E2.3 Sportline
Re: Possibly worn valves or seals allowing oil to enter the head.As a general rule black s
Black smoke is usually rich fuel mixture. Blue is usually oil. White can be water or very bad oil problem, among others.
Technical Officer, Mercedes-Benz Club (NSW) Inc.
www.mbcnsw.org.au
107.023: 1973, 350SLC, auto, icon gold, parchment MBtex.
107.026: 1981, 500SLC, auto, thistle green, green velour.
124.090: 1990, 300TE, auto, arctic white, cream-beige MBtex.
201.028: 1990, 190E-2.3 Sportline, 5-speed manual, arctic white, blue leather.
201.028: 1990, 190E-2.3 Sportline, auto, signal red, black fabric (parts car, currently dismantling).
Greg in Oz is offline   Reply With Quote
Old 08-25-2003, 06:21 PM   #4 (permalink)
Black Smoke -380 SL
Dear Benz Brothers,
We found the problem to be the warm-up regulator[:O].
It's the aluminum device staring you in the face at the front of the engine just left of center.
[:D]She is running smoother than smooth.[;)]
The component was about 550 USD. Let me know where I should be getting our parts if you will?
Aleks
Windsor, Ontario, Canada[;)]
Old 08-25-2003, 06:25 PM   #5 (permalink)
black smoke - 380 Sl
Thank-You Benz Brother HECKFLOSSE.
found it to be the "warm-up regulator"
Aleks
Old 10-02-2006, 11:36 AM   #6 (permalink)
Date registered: Sep 2006
black smoke
I have replaced just fuel distributor, spark plugs, fuel pumps, OEH valve and still get blck smoke after a while may be 15 miles. Any sugestions. In the morning the car smooth as a baby's a.. but after 10 to 15 miles black smoke develops at all speeds. I am contemplating to replace the O2 sensor. Any sugestions?
Thank you
tungsten c is offline   Reply With Quote
Old 10-02-2006, 05:36 PM   #7 (permalink)
nobby's Avatar
Date registered: Feb 2005
Vehicle: '83 280 SL 5 speed
Aleks,
GERMANSTAR .... I paid $225 plus a core charge of I think $25.00. Plus shipping of I think $25. All US funds. To Barrie Ontario. The dealer wanted $1250.00 and my first born.
Why do psychics have to ask you your name?
nobby is offline   Reply With Quote
Old 10-03-2006, 05:37 AM   #8 (permalink)
A&L's300SL's Avatar
Date registered: Apr 2006
Vehicle: 87 300SL "Roadster" 86 420SEL "Limo"
Thank you
It would help if you say what model you have. I had a similar problem.
As above try the cold start injectors and check your fuel for contaminants like rust or water.
If I had done this first it would have saved me a fortune.
Good luck
Andrew
87 300SL [A classic roadster for a run through the hills]
86 420SEL [A big Benz limo for a night out with friends]
"That's the way I like it baby, I don't want to live forever"- Lemmy
A&L's300SL is offline   Reply With Quote
Old 10-03-2006, 10:54 AM   #9 (permalink)
model number
I have a 560 Sl 1989
