Hats for the Discerning 107 Driver - Mercedes-Benz Forum
post #1 of 34 (permalink) Old 06-18-2017, 06:09 PM Thread Starter
jaymaynard's Avatar
Date registered: Mar 2013
Vehicle: 2008 ML320CDI 4Matic, 171K miles; 1987 560SL (die Weisse Lady), 117K miles
Quoted: 409 Post(s)
On my road trip with the top down today, I discovered a problem I hadn't quite anticipated: My hat didn't want to stay fully on my head.
I've been using a baseball cap from my employer. It's worked fine for me driving back and forth to work and suchlike, but at 70 MPH, it became clear another solution was needed. I pulled over and tightened the strap as tight as I could and still get it seated on my head, and that worked, but it seems a non-optimal solution.
What kind of hat do the rest of you wear? (Those of you with a full head of hair who don't have to worry about sunburned scalps...keep your snickering to yourselves. )
"Engineered like no other car in the world." That's both a bug and a feature.
jaymaynard is offline
post #2 of 34 (permalink) Old 06-18-2017, 06:22 PM
rowdie's Avatar
Date registered: Jun 2008
Vehicle: 1986 560SL: '84 500SL: '84 280SL 5 speed: other 107s
Quoted: 102 Post(s)
Had this problem. The solution is a wind screen.
rowdie is offline
post #3 of 34 (permalink) Old 06-18-2017, 06:25 PM
okyoureabeast's Avatar
Date registered: Mar 2017
Vehicle: 1984 380SL
Quoted: 38 Post(s)
Who needs a hat when you've got hair?
ducks
okyoureabeast is online now
post #4 of 34 (permalink) Old 06-18-2017, 06:38 PM
rowdie's Avatar
Quoted: 102 Post(s)
Even in the early 70s when I had a full head of hair and an MGB I needed cover when driving top down.
rowdie is offline
post #5 of 34 (permalink) Old 06-18-2017, 06:53 PM
Rhinoww's Avatar
Date registered: Jan 2015
Vehicle: 1984 380SL
Quoted: 79 Post(s)
My solution so far has been to tighten down the hat as much as possible comfortably and not to wear expensive to favorite hats. I'm 6 2 and sit up high, so perhaps a bit more vulnerable. Wind screen helps a lot but I like the wind.
Rhinoww is offline
post #6 of 34 (permalink) Old 06-18-2017, 06:55 PM
rowdie's Avatar
Quoted: 102 Post(s)
I like breaking wind.
rowdie is offline
post #7 of 34 (permalink) Old 06-18-2017, 07:12 PM
CavallinoRed's Avatar
Date registered: Apr 2008
Vehicle: 1988 560SL 50K
Quoted: 67 Post(s)
Yep. Rowdie's simple solution is "hats on". If you don't have a wind blocker/screen yet really is a must have R107 option.
CavallinoRed is online now
post #8 of 34 (permalink) Old 06-18-2017, 08:37 PM
PanzerPuff's Avatar
Date registered: Dec 2013
Vehicle: 1987 560SL
Quoted: 604 Post(s)
Try weldwood contact cement.
Failing that, thumb tacks.
PanzerPuff is offline
post #9 of 34 (permalink) Old 06-18-2017, 09:37 PM
roncallo's Avatar
Date registered: Apr 2005
Vehicle: 1986 560SL with M120 V12 Engine, 1988 560SL Stock
Quoted: 295 Post(s)
I use a visor. But last week I did get a sunburn through my hair.
roncallo is offline
post #10 of 34 (permalink) Old 06-19-2017, 12:50 AM
Date registered: Apr 2006
Vehicle: 1983 380SL, 2000 S430, 1991 420SEL (retired) - RHD
Quoted: 243 Post(s)
English style caps are not as prone to suck-off in the wind as the golf caps. There's nothing worse than suck-off at 60mph!
Aussiemerc is offline
