Digging deeper into my timing issue, took off the cam cover and measured the chain stretch. What do you think, too much?
Pelican parts how to guide states "When the crankshaft is at TDC "0", the timing marks on the cam stands must never be early, however they should be right on or slightly late" which is true on this case but I don't know how "slightly" is slight enough
Cam is the passanger side bank. I painted the 0.0 mark with white paint
Thank you all
Thank you all
