I have tried searching to identify this vacuum line which I accidentally disconected whilst removing the RHS valve cover. A search indicates it is for the Check valve? But the connection seems to have come loose from under the coolant tank, but I cannot for the life of me see where I can reconnect? Can someone post a pic of the connection point? Maybe mine has broken.....
Anyway, car is running really rough since this and the oil change I did at the same time. Sounds like it is missing (popping sound, and engine shake at idle), sparks and plugs ok. So maybe something related to the fuel flow? If still continues after reconnect the vacuum line then suspect the fuel injectors next.
