Hey guys,
I have been chasing down a rough running issue for a couple of months, gradually changing out parts that i think are contributing to the issue as fast as i can save the money to do so. Im at the stage where i need to get this sorted otherwise the car won't get registered in time and will have to have a full inspection which is a massive pain!
I have reached a point where i am a bit stuck in terms of the fuel injectors. i pulled them out a couple of weeks ago and the rubber seals are completely dead so that would be a major factor in why its running rough, they're also covered in soot which i assume is a bad thing.
The main issue i have though is that i am not sure whether or not i need the plastic casing that goes around the injectors. None of the injectors currently in there have these sleeves in place and they seem to fit well into their existing position but everything i look at has these sleeves.
Could someone please advise or show me what their m103 engine injector set up looks like as well as the part number for the rubber seals (i have the injectors number).
I will attach images ASAP.
Thanks as always!
Thanks as always!
