Turn signals out
1K views 9 replies 5 participants last post by  noeljb
Turn signals out but everything on the fuse working, my question is if one bulb is out will all signals not work?
#5 ·
Thanks for this post! I had the same problem, turn signals would mysteriously stop working. Cycled the emergency flasher switch everything started working. Now I am going to soak the E-flashers switch with electrical deoxidizer (miracle solution for old automotive analog electrical components). Thanks again!
#8 ·
Pull your fuses, clean the terminals, and replace with copper fuses. I only got halfway done doing mine before it got cold and the flasher fuse(s) are on the half that didn't get done before it got cold. 2nd thing to do when the weather warms up. First thing is to put air in the tires.
