1985 380 sl. Car cranks, but will not turn on.
I have checked coil, green condenser wire, icm, pick up coil from ignition distributor, and no current. the only current I have is the red wire at bottom of coil coming from icm.
was thinking of replacing ignition switch next?
Not sure if it's two problems or if they are related, but instrument cluster is going all over the place when I turn lights on.
when I push turn signal to either position the light in the instrument cluster, start to flicker at the rythem of the flashers.
When I test for short with test light, fuse 12, when removed turned test light off.
also, when I crank car, the all the light on the dash go aff, with the exception of the battery light. Now my battery light never came on while car was running.
been stranded for 10 days, now. the day the car would not turn over, my battery, was fully charged. there was no drain, over night.
any impute, would really help???
My brain, is fried, just as when i had my stroke. Ouch!!!!
thanks for reading.
thanks for reading.
