88' 560SL rough idle question - Mercedes-Benz Forum
post #1 of 11 (permalink) Old 08-11-2013, 05:02 AM Thread Starter
2-th-max's Avatar
Date registered: Jul 2013
Vehicle: 1988 SL 560, 2002 M3 cab, 2007 MDX, 2011 R8 5.2, 2012 GS450 AWD
Purchased an 88' 560SL in June 129,400 miles and notice it did not idle well when engine was warm. Not sure how long the car had been sitting prior to purchase (old gas?). I had it tuned-up including plugs, all fluids and filters replaced. Put injector cleaner in tank. Had vacuum hoses replaced. I have driven it about 200 miles and the rough idle now comes and goes. Sometimes it idles like a kitten while other times (5 min later) like an old tractor. It has even died a time or two when trying to leave a red light and then is a little hard to start. Once underway it runs great. My diagnosis is a partially clogged injector(s) which clear and then gets reclogged again and should improve over time and with additional injector cleaner. My mechanic says it may be a vacuum leak at the intake manifold, and he also mentioned fuel pump relay, but why would these causes be intermittent? Are there anyother thoughts? Is this a common issue in these cars?
Also yesterday out of no where the tachometer stoped working for about 5 min and then started back fine. This is the first time this has happened???
2-th-max is offline
post #2 of 11 (permalink) Old 08-11-2013, 12:57 PM
Date registered: Jan 2007
Quoted: 85 Post(s)
This sounds to me like the ignition control module is on its way out. It sends the RPM signal to the tach and idle speed control relay.
Vacuum leaks are not come-and-go, and the fuel pump relay will kill the engine, not make it idle rough.
Chuck Taylor
Falls Church VA
1998 SL500
1959 220S
1970 280SL
ctaylor738 is offline
post #3 of 11 (permalink) Old 08-11-2013, 01:11 PM
jsebastian's Avatar
Date registered: Sep 2011
Vehicle: 1967 250 S (sold) 1986 560 SEC 1987 560 SL
Quoted: 72 Post(s)
when I replaced my fuel distributor with a used eBay unit, my rough idle mostly stopped. Apparently, the many orings in it deteriorate causing blockages and internal leaks.
good luck,
John
jsebastian is offline
post #4 of 11 (permalink) Old 08-11-2013, 09:31 PM
yka
yka's Avatar
Date registered: Dec 2008
Vehicle: US spec MB560SL 1986, Audi A4 2pcs, Ford Taunus 1964 17M and 2.0 1975
Quoted: 53 Post(s)
Send a message via Skype™ to yka
Check also the Idle Air Valve
Idle Air Valve is adjusting the idle speed constantly - if this air valve is dirty or clocked the result is high or rough idle and stalling depending if it is too open or too closed. Cylinder shape valve can be cleaned with WD40 or similar.
Idle Air Valve is top and front of the engine, between FD and ignition distributors.
Yka
Ei riemulla rajaa kun saa mersulla ajaa
There is rejoicing when the limit allowed to drive a Merc
yka is offline
post #5 of 11 (permalink) Old 08-12-2013, 05:01 AM
dgosh28's Avatar
Date registered: Oct 2011
Vehicle: '71 250, '78 450SLC 5.0, '78 450SL, '81 380SLC 5.6, '89 260E, '15 Kia Sorento
Quoted: 103 Post(s)
I have exactly the same issue with my 380SLC 5.6. Thanks for posting this thread. Hopefully, we will find a solution. If I find one I will post the results here as well.
dgosh28 is offline
post #6 of 11 (permalink) Old 08-23-2013, 09:51 AM Thread Starter
2-th-max's Avatar
Thanks everyone for the replys. I am getting it out of the shop Monday with a new ignition coil and new fuel relays. I will report back if this takes care of the issue.
MM
2-th-max is offline
post #7 of 11 (permalink) Old 08-23-2013, 10:41 AM
pantera1683's Avatar
Date registered: Apr 2006
Vehicle: 1982 500 SL AMG
I am curious to see if either of those fixes your problem.
pantera1683 is offline
post #8 of 11 (permalink) Old 08-30-2013, 05:49 PM
Update please
post #9 of 11 (permalink) Old 09-09-2013, 03:10 PM Thread Starter
2-th-max's Avatar
UPDATE:
2 weeks post repair and the 88 560sl is running much better. The rough idle has all but cleared. It has not died or tried to stall once at idle since the repair. It starts quickly and runs well at all speeds. I have now taken it for 4 separte 20 mile interstate runs at 80+ mph on hot days near 90F and it runs out great. I have to believe it was the ignition coil given the tachometer issue I notice. The fuel relays were probably over kill. I am very happy with the results. Next up Odometer repair and then air conditioner next spring. I would also like to find some extended lug bolts for the stock wheels.
I like this auto more and more each day:-)))
2-th-max is offline
post #10 of 11 (permalink) Old 09-09-2013, 10:44 PM
Date registered: Nov 2006
Originally Posted by 2-th-max View Post
UPDATE:
In the meantime, before you have your odometer repaired, if you have an iPhone or a copy of one, there is an app that you can download called Odometer+ that will track your milage on trips. My odometer went out too, but I used the app to track a 6500 mile trip I took inn my '85 380SL this past June-July for monitoring my gas milage. BTW I averaged 22 MPG...
calotto is offline
