Hood does not unlatch when Release Lever is pulled - Mercedes-Benz Forum
post #1 of 10 (permalink) Old 05-21-2013, 02:42 PM Thread Starter
cwmoser's Avatar
Date registered: May 2004
Vehicle: 1983 380SL, ivory/dk brown, 44k miles, dual roller timing chain. 1986 560SL, red/white, 184K mile.
Quoted: 1110 Post(s)
The hood on my 560SL does not pop loose when I pull the Hood Release Lever.
Have to have wifey apply upward pressure on hood as I Pull lever to get it loose.
Comparing my 380SL which works fine with the 560SL, I noticed that the rubber pieces
around the Hood Springs are missing on the 560SL. Are these what cause the
Hood to pop loose?
Carl
Carl
"You have chosen to drive a MERCEDES-BENZ, a car in whose construction and production we have taken great pains because we believe that quality is not a matter of chance." -- page 3, Owners Manual 380SL
Timing Chain, Subframe, wiring harness, Climate Control, Rust prevention, etc.
cwmoser is online now
post #2 of 10 (permalink) Old 05-21-2013, 04:11 PM
Date registered: Sep 2008
Vehicle: 1975 450SL
Quoted: 15 Post(s)
Hood to pop loose?
Carl
I think those are to prevent the springs from hotching up the paint next to them if they vibrate when the hood is closed.
Usually, the hood not popping open is adjustment of the latch or the little rubber covered bumbers at teh front corners of the hood. Maybe the rubber has gone from age?
Just a wild guess,
Scott
RadioTek is offline
post #3 of 10 (permalink) Old 05-21-2013, 04:21 PM
w108,107 Parts Hoarder
Fonzi's Avatar
Date registered: Jun 2010
Quoted: 1679 Post(s)
There's a pin in front of the hood latch. Give it some oil. The pin sits on a spring inside a sheet-metal-thick cylinder which can bend (under the radiator support) and cause friction allowing the pin to get stuck in the down position, not constantly applying upward pressure on the hood. I have noticed the problem if you press down hard on the hood after it has latched, moving that pin a little deeper in the cylinder than normal where it gets stuck.
Sent from AutoGuide.com App
My signature:
Click for list of my 32 MB since 2010. If, you want 70's-80's Mercedes tuner wheels, let me know.
Fonzi is offline
post #4 of 10 (permalink) Old 05-21-2013, 04:34 PM
rovert's Avatar
Date registered: Jan 2010
Vehicle: 1984 500SL
Also, the release cable stretches over time. There is an adjustment nut where the cable sheath connects to the latch assembly under the hood. If your cable is indeed stretched, you might have a few turns left on this nut to compensate for it.
rovert is offline
post #5 of 10 (permalink) Old 05-21-2013, 05:18 PM Thread Starter
cwmoser's Avatar
Fonzi, thanks. Mystery solved.
My red 560SL does not have that pin. The PO must have removed it.
Below are photos of my ivory 380SL with the pin, and my red 560SL with that pin missing.
Can just the pin be ordered?????
Carl
ID:	516805   Click image for larger version
Carl
post #6 of 10 (permalink) Old 05-21-2013, 07:30 PM
Fonzi's Avatar
Carl
I think the whole assembly comes together. You can get one from any salvage 107 probably.
My signature:
Fonzi is offline
post #7 of 10 (permalink) Old 05-21-2013, 08:39 PM
reno4u2's Avatar
Date registered: Dec 2009
Vehicle: 1988 560SL (California Model)
Quoted: 705 Post(s)
Carl
Doesn't look like it...part number is 1158800160 for the entire piece. Start hitting the salvage yards or maybe someone here can supply one. I was shocked at the price of a new one. Actually hope I made a mistake looking it up but I don't think so.
$700 MSRP
$500 Parts.com
reno4u2 is online now
post #8 of 10 (permalink) Old 05-22-2013, 04:27 AM Thread Starter
cwmoser's Avatar
$700 MSRP
$500 Parts.com
Ouch. I bet I could make one out of a screw and a spring before I would pay that price.
Thanks
Carl
Carl
post #9 of 10 (permalink) Old 05-22-2013, 07:19 AM
reno4u2's Avatar
Quoted: 705 Post(s)
Thanks
Carl
Big time ouch! I did a search on EPC and it looks like the part was used on many different models...
100,107,108,109,110,111,113,114,115,116,123
Wouldn't think it would be too hard to find one at a salvage yard or someone parting out a car.
post #10 of 10 (permalink) Old 05-22-2013, 12:14 PM
rowdie's Avatar
Date registered: Jun 2008
Vehicle: 1986 560SL: '84 500SL: '84 280SL 5 speed: other 107s
Quoted: 97 Post(s)
Carl,
You got mail.
rowdie is offline
