Is there a step by step Pertronix install - Benzworld.org - Mercedes-Benz Discussion Forum
» Auto Insurance
» Featured Product
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Roadster Forums > R/C107 SL/SLC Class
Old 02-26-2013, 04:10 PM   #1 (permalink)
Date registered: Aug 2012
Vehicle: 1975 450SL
Received my Pertronix 1885 and coil for a a 1975 450SL and preparing to install. Is there a thread that will take you thru the install with elimination of switchgear? I have read bunches of threads about installs with problems and when I am done reading more confused then before I started. Also do I need another ballast resistor for install so the tach works properly if so what ohm rating?
Thanks for all help
center valley is offline   Reply With Quote
Old 02-26-2013, 04:36 PM   #2 (permalink)
maynardg's Avatar
Date registered: Jun 2010
Vehicle: 1972 350SL; 1999 E320 Wagon
http://www.benzworld.org/forums/r-c1...975-450sl.html
Follow the posts by MBGraham within this thread. Works perfectly.
http://www.benzworld.org/forums/r-c1...onix-tach.html
8.2K resistor worked for me.
www.obiterscripta.blogspot.com
maynardg is online now   Reply With Quote
Old 02-26-2013, 07:49 PM   #3 (permalink)
MBGraham's Avatar
Date registered: Oct 2006
Vehicle: '72 350SL, '85 300D, '98 E320, '06 Smart cdi
Not exactly step by step, but may suffice:
PeachParts Mercedes ShopForum - View Single Post - manual how to adjust the 3.5 engine (ignition and A/F ratio)
Someone over there asked about same thing for his 300SEL!
ADDED: Oops. I failed to notice OP had a 75 model. But Michncraig has that covered. Seems it is more difficult, but still do-able.
MBGraham is offline   Reply With Quote
Old 02-26-2013, 11:32 PM   #4 (permalink)
michncraig's Avatar
Date registered: Oct 2010
Vehicle: 1975 450SL
Hi, I started the thread about the '75 install linked by Maynard above. Unfortunately it's not as clear as it could be because of the problems I had getting it sorted, but one important take away is that our 75 distributors are a little bit different than other years and the mounting needs to be modified a little bit to make it fit. There are pictures of what I did, and you can probably do better learning from my mistakes. Also, be sure to document the original wiring in case you need to revert back to points at any point in the future.
Good luck, and post back if you have any questions when you get into it, there are several folks on here who are running the pertronix set-up.
Sent from AutoGuide.com App
michncraig is offline   Reply With Quote
Old 02-26-2013, 11:48 PM   #5 (permalink)
Date registered: Sep 2002
Vehicle: 1975 450SLC, Previous: 1989 190E 2.6, 1997 E420, 1985 380SL
I'd slap one of these into my '75 in a heartbeat if I knew it would be a slam dunk.
nathanso is offline   Reply With Quote
Old 02-27-2013, 04:30 AM   #6 (permalink)
Premium Member
Date registered: Sep 2008
Vehicle: 1975 450SL
Premium Member
Re: Is there a step by step Pertronix install
Not exactly a slam dunk, but very nearly is the Crane/S&S conversion kit for a '75. At least it was for my case. The dizzy or the bracket didn't need to be modded. The hardest part was to fab up a mounting bracket for the electronics box to fit in the same holes as the original switchgear. It was a little more but not too much.
I think mine was $107.00 a few years ago. I considered it prophetic when I saw the price.:-)
Scott
Sent from my Nexus 7 using AutoGuide.Com Free App
RadioTek is online now   Reply With Quote
Old 02-27-2013, 03:51 PM   #7 (permalink)
The Proctologist's Avatar
Date registered: Jun 2011
Vehicle: 1972 350SL 148,000 miles
add the flamethrower and shave the flange and it's a slam dunk, the actual work will take about ten minutes, the head scratching, forum reading and beer drinking takes about 2 hours
it's super simple and it improves performance noticably
Build a man a fire and he will be warm for a night, set a man on fire and he will be warm for the rest of his life
Vada a bordo, Cazzo!!!
The Proctologist is online now   Reply With Quote
Old 02-27-2013, 07:29 PM   #8 (permalink)
Is it correct that the Pertronix system replaces just the points and still uses the stock switchgear, whereas the Crane system replaces both the points and the switchgear? I'm all for replacing as many as the original ignition components as possible.
Old 02-28-2013, 04:21 AM   #9 (permalink)
maynardg's Avatar
Do both the Pertronix ignition and the Flamethrower coil and the switchgear comes out. Pertronix alone does not accomplish that.
Old 03-08-2013, 04:59 PM   #10 (permalink)
Vehicle: 1975 450SL
pertronix install Extra wire to + side
I have the system almost complete except for one item. In the diagram shown on the pertronix install there is an extra wire that runs to the positive side of battery. Does this have to run direct to the battery. The reason I ask my battery is in the trunk.
Thanks
Bookmarks
