My timing chain guide thread - Benzworld.org - Mercedes-Benz Discussion Forum
» Auto Insurance
» Featured Product
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Roadster Forums > R/C107 SL/SLC Class
Old 02-09-2013, 10:28 AM   #1 (permalink)
brentkhack's Avatar
Date registered: Nov 2006
Vehicle: 88 560 SL (daughters), 12 Volvo C70 (wifes), 04 Navigator (mine)
So I am fully into the passenger side. I have the cam sprocket off and the right side guide off. I am looking at changing the tensioner guide and took out the lower bolt as you can see from the pic. But I do not know what is keeping the whole slide rail in.
brentkhack is offline   Reply With Quote
Old 02-09-2013, 10:43 AM   #2 (permalink)
yka
yka's Avatar
Date registered: Dec 2008
Vehicle: US spec MB560SL 1986, Audi A4 2pcs, Ford Taunus 1964 17M and 2.0 1975
Send a message via Skype™ to yka
Here you are, look the pics. I used these easy and simple home made "tools" to pull out the slide holder pins.
There are better and more professional tools available.
My timing chain guide thread-chain-rail-pin-removal-tool-1   My timing chain guide thread-chain-rail-pin-removal-tool-2   My timing chain guide thread-chain-rail-pin-removal-tool-3
Yka
Suolahti Suolahtelaisille! .
yka is offline   Reply With Quote
Old 02-09-2013, 10:46 AM   #3 (permalink)
brentkhack's Avatar
I do have Rowdie's pin puller. Sorry I didn't try that with this one. I thought whatever was keeping it in was bigger than the pin puller I am using.
Old 02-09-2013, 10:52 AM   #4 (permalink)
rowdie's Avatar
Date registered: Jun 2008
Vehicle: '73 450SL: '81 280SL: 1986 560SL: '84 500SL AMG: 1984 280SL 5 speed (Strassenkröte)
That one isn't threaded on the inside (on yours). It is just a floating pin with nothing holding it. Try wedging something in the hole at a slight angle and pulling. .
rowdie is offline   Reply With Quote
Old 02-09-2013, 10:54 AM   #5 (permalink)
brentkhack's Avatar
Here is the one I am using, but doesn't seem to be the right size.
Old 02-09-2013, 11:10 AM   #6 (permalink)
brentkhack's Avatar
Im trying to use a screwdriver but no luck. I will keep looking for something else. Would PB Blaster help?
Old 02-09-2013, 12:38 PM   #7 (permalink)
rockcrusher's Avatar
Date registered: Nov 2009
Vehicle: 1984 380SL euro
fill the cavity of the pin with some epoxy glue, insert a bolt, let it harden, then pull the pin out. or you could fill the cavity with epoxy glue, coat a bolt with some oil or fine grease, thread it into the epoxy, let it harden, then pull the pin, remove the bolt. just a thought.
If I knew I was going to live this long, I would have taken better care of myself and saved more money
rockcrusher is online now   Reply With Quote
Old 02-09-2013, 12:40 PM   #8 (permalink)
reno4u2's Avatar
Date registered: Dec 2009
Vehicle: 1988 560SL (California Model)
Any lubricate wouldn't hurt. IIRC I used a large easy-out to remove the pin. Mine had a small burr on it preventing its removal.
reno4u2 is offline   Reply With Quote
Old 02-09-2013, 12:44 PM   #9 (permalink)
brentkhack's Avatar
Any pics and what size. Will look into the epoxy glue method too.
Old 02-09-2013, 12:52 PM   #10 (permalink)
if you do the epoxy method, clean the cavity out with a contact cleaner first to make sure the glue sticks.................
lock tight makes a product for thread repair, it has an epoxy and release agent for the bolt. use the same and thread size as your puller, then you would be good to go for future pin removal.
Bookmarks
