Economical wiper refills $6 each - Benzworld.org - Mercedes-Benz Discussion Forum
» Auto Insurance
» Featured Product
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Roadster Forums > R/C107 SL/SLC Class
Old 02-04-2013, 01:25 PM   #1 (permalink)
Fonzi's Avatar
Date registered: Jun 2010
Vehicle: 1973 10704412007016-soon4sale 10702612000478-convertible
Perhaps others have covered this and I don't already know. Perhaps there are cheaper or better options out there, but I don't know.
Here is what I do know, $6 at autozone and I have a part number that works.
The 17.5" blades from my 280slc are the same length as 18" blades in the store. Since refills are no longer sold, you just buy the whole arm (and deplete the earth's natural resources for no reason). So here is what I bought:
It might not be so easy to tell from the pictures, but the gold-ish clip at the end of the plastic reinforced (not metal reinforced like the inserts I removed) insert is what holds the blade from sliding out one end or the other. It is very easy to squeeze and slide the blade insert out of the new one without any damage. Then it just clips right into place in the original stainless blade holder. There is nothing at the other end holding it in.
Black blade is what came with the $6 value craft blade. It looks nearly identical to the boast blade. Heck, if you don't want to pay an arm and a leg for blades that would look OEM, strip these down to bare metal, or just paint them silver.
This may not be original quality, but it beats the blade that was falling apart.
Also, I think that maybe SLC cars got 17.5 (aka 18") blades and SL cars got 18.5" (aka 19") blades. This was for my 280slc. So I obviously used 18" for that reason.
The value craft blade was $6 at Autozone. I have read that MB wants closer to $16. There are many options at Autozone in the $12-18 range, but at those prices, I would buy MB. This was the cheapest, and not what the guy in the store recommended to me. He recommended something much more like the original with rubber stops instead of the metal clip on the end. I think it was $9, and I think I might have been more likely to ruin it. So I went the cheap route.
Thought I'd share since I don't recall seeing this covered here.
Sent from AutoGuide.com App
R107 Parts Wanted: washer bottle (1978), blue r107 visors, 107 trunk spare tire well, 107 headlight wiper arms
w107 FS/trade/giveaway: 4 silver BBS RS009 8x16 et11 (won't fit front of 560sl without spacers and smaller lips), D-jet parts, 1975: (wiper motor, multiswitch, coil, injectors, etc.), US headlights, a black 1973 450sl
Fonzi is offline   Reply With Quote
Old 02-04-2013, 03:19 PM   #2 (permalink)
Date registered: Sep 2010
Vehicle: '85 380SL (145Kmiles), '83 300D, '82 240D stick, '80 300SD, '77 240D 3 VW Diesels, Triumphs, Citroen
I have the same gripe about refills. For some time I could find these Taiwanese twenty something inch $1 pairs of refills that I could have on hand that would trim down and fit anything. Nothing lasts more than a year outside in Florida.
rs899 is online now   Reply With Quote
Old 02-04-2013, 04:13 PM   #3 (permalink)
Fonzi's Avatar
Since I will certainly need a few sets of inserts, I thought I'd try the insert our base route and bought a set of these at only $7 for the pair.
Look at this on eBay:
Wipe-Away 18" Wiper Refills 2-Pack Signaltone-Neiman
http://bit.ly/XSOAZX
(My SLC take 18". Measure yours. Don't assume they are the same.)
There are some 22" out there, but most look like NOS, and I don't know about buying old rubber, whether it is used or not.
Old 02-04-2013, 04:20 PM   #4 (permalink)
caseSEA's Avatar
Date registered: Sep 2011
Vehicle: 1981 380 SLC, 2003 E 500
I got Bosch refills for $7.14/pair from Autohaus AZ and they were a perfect fit:
Your Parts Search Returned 1 Part(s)
caseSEA is offline   Reply With Quote
Old 02-04-2013, 04:42 PM   #5 (permalink)
Date registered: Dec 2004
Take your old blade to O'Reilly's and they'll match refills from behind the counter. They can match them on length and width. In many cases, if you just match on length, they will not fit right and slip.
With best regards
Al
Check out the W114, W115 /8 enthusiast forum http://www.stroke8.org
alabbasi is offline   Reply With Quote
Old 02-04-2013, 05:05 PM   #6 (permalink)
reno4u2's Avatar
Date registered: Dec 2009
Vehicle: 1988 560SL (California Model)
Good find. Shipping will kill you unless you add them to an order that exceeds $50. Not hard to do with all I order from them.
ps...an old trick. Take some wet/dry 600 grit or so sandpaper, wet it and fold it into a V. A couple of swipes up and down the blade will extend their life...if they are not too badly chewed up.
reno4u2 is offline   Reply With Quote
Old 02-04-2013, 05:29 PM   #7 (permalink)
It Is What It Is, Dude
isthisdave's Avatar
Date registered: Mar 2006
Vehicle: 1978 107.024 RIP
The correct for MB Bosch wiper refills can be bought at any reputable parts house.
isthisdave is offline   Reply With Quote
Bookmarks
