Gas Tank Cleaning... - Benzworld.org - Mercedes-Benz Discussion Forum
» Auto Insurance
» Featured Product
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Roadster Forums > R/C107 SL/SLC Class
Old 01-14-2013, 06:22 AM   #1 (permalink)
Date registered: Dec 2012
Vehicle: '79 450 SL..'06 Hummer H3.."01 Durango R/T..'84 Ford F-150 HO..'62 TBird Convertible..
Location: Ash Flat, Ar..Moved here from West Palm Beach..to live in the country !!
I've been reading suggestions about the best ways to clean..and seal ??..my 450 tank. Larry is rebuilding the Fuel Dist...so I'm wanting to do this right. The strainer and sender both came out easily..The strainer was not clogged badly..and there was a little rust/varnish ??? around the openings when I ran my finger around on the inside. Larry said he uses Hydrochloric acid in his rebuilds..and says the tanks are galvanized. Is there a final word on this subject ? I'm afraid of a lining material breaking loose..and starting the problem all over again..Suggestions ?...thanks..
ozark1 is offline   Reply With Quote
Old 01-14-2013, 07:36 AM   #2 (permalink)
roncallo's Avatar
Date registered: Apr 2005
Vehicle: 1986 560SL with M120 V12 Engine, 1988 560SL Stock
Rust in the fuel distributor probably did not migrate from the tank. It more than likely came from the fuel lines or fuel distributor itself.
Flush out fuel lines. Install a new strainer in the tank and a new fuel filter. Replace all fuel lines on the fuel pump cluster. You may also want to check the pump.
roncallo is offline   Reply With Quote
Old 01-14-2013, 07:58 AM   #3 (permalink)
Date registered: Jan 2004
I used the Renu guys for my fuel tank on my ponton 15 years ago and couldn't be happier.
Gas Tank RENU - USA
Len
'59 220S Cabriolet
'83 240D original owner 348,000 miles
'88 560SL 41,000 miles being parted out - https://sites.google.com/site/mercedesstuff/home
'99 E300 turbo 170,000 miles
'03 SLK320 27,000 miles
sokoloff is offline   Reply With Quote
Old 01-14-2013, 08:32 AM   #4 (permalink)
petesmga's Avatar
Date registered: Aug 2009
Vehicle: 1979 280sl 4 sp w/ac 1984 280sl auto w/ac 1998 volvo xc/70
POR-15 also makes a paint/coat for the tank. I've used on numerous cars, bikes and on diesel tanks.
petesmga is offline   Reply With Quote
Old 01-14-2013, 08:38 AM   #5 (permalink)
The car started and ran..for a while. It has not been driven in 3-4 years.The fuel distributor is being rebuilt. I have a new strainer and filter..and the short lines. The tank has been pressure washed..I have had suggestions from lini ng..which I think is inviting trouble..to Hydrochloric acid..that's what Larry at CIS uses on the FD rebuilds..to..vinegar..to nuts and bolts rattling around in the back of a truck..I think..I'll just use all new parts..run it a while and change the filter..The lining material..regardless of the brand..scares me..Has MB ever put out a memo on this problem ?..PS..I'm WAY far away from RENU...
Old 01-14-2013, 08:44 AM   #6 (permalink)
I'm familiar with POR..I've heard good and bad...A friend with a Sunbeam Tiger used Bill Hirsch's brand ...probably the same stuff. He says it's OK..but has found it in his filters..
Old 01-14-2013, 08:59 AM   #7 (permalink)
reno4u2's Avatar
Date registered: Dec 2009
Vehicle: 1988 560SL (California Model)
Don't some if not most radiator repair shops have the equipment to do gas tanks? I would look around locally.
reno4u2 is offline   Reply With Quote
Old 01-14-2013, 09:16 AM   #8 (permalink)
The tank is at a radiator shop now..getting high pressure cleaning inside. He will line the tank..if I want it. I've just not heard of good results..over the long run..with POR or any of the other brands...
Old 01-14-2013, 09:31 AM   #9 (permalink)
Here's a new one. A hot rod friend in Florida said to get a couple bottles of.."The Works"...toilet bowl cleaner. Pour it in..slosh it around..rinse and dry !!
Old 01-14-2013, 09:39 AM   #10 (permalink)
Date registered: Sep 2005
Vehicle: 1973 450SL
Depending on how serious you are, you could take the tank to a plating shop and have the tank nickel plated. Nickel plate will not flake off or rust ever again. Also depends on how bad the tank is now. If bad enough, it won't be platable.
Craig S
1973 450SL
mbslns is offline   Reply With Quote
Bookmarks
