Idle screw? - Page 2 - Benzworld.org - Mercedes-Benz Discussion Forum
» Auto Insurance
» Featured Product
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Roadster Forums > R/C107 SL/SLC Class
Old 01-06-2013, 08:04 AM   #11 (permalink)
nobby's Avatar
Date registered: Feb 2005
Vehicle: '83 280 SL 5 speed - The PIG
Originally Posted by bradsscooters View Post
I know, just nothing specific for the 1983 500 SL I recently picked up.
You don't need the specifics of the 500SL....just the theory. I have a 280 and have to adapt most info to my needs.
That mixture screw is the LAST thing to fiddle with.
If you have a cold start problem you should trouble shoot the cold start valve first. That valve gives a cold engine a snort of gas...............kinda like manually pumping a gas pedal on a carburated engine.
An eye for an eye only makes the whole world blind.
nobby is offline   Reply With Quote
Old 01-06-2013, 08:08 AM   #12 (permalink)
bradsscooters's Avatar
Date registered: Jul 2010
Vehicle: 1989 560 SEL, 1993 400 SEL, 1986 420 SEL, 1977 450 SL, 1984 300D, 1981 380 SL, 1983 500 SL
Nobby, I'm looking at it now. When I turn the key to the "on" position, shouldn't I get voltage at the plug, like with the ICV, or is it opposite, meaning that voltage won't exsist until the car is warmed up? Just need to clarify this.
bradsscooters is offline   Reply With Quote
Old 01-06-2013, 08:13 AM   #13 (permalink)
nobby's Avatar
To what? The CSV?
You would only get a quick 'flash' of voltage there...me thinks.
The best way to see is if it's working is to remove the cold start valve from the intake and put a container underneath it. Then (engine cold) turn the key and see if the valve squirts into the container.
Old 01-06-2013, 08:22 AM   #14 (permalink)
Okay, I will give that a try. Is there a gasket there that would need replacing?
Old 01-06-2013, 08:34 AM   #15 (permalink)
petesmga's Avatar
Date registered: Aug 2009
Vehicle: 1979 280sl 4 sp w/ac 1984 280sl auto w/ac 1998 volvo xc/70
There is a gasket but it usually comes off clean, if not anthing in a tube. I think the CSV is a little more than a 1 time snort, maybe 10-15 secs worth of extra gas.
petesmga is online now   Reply With Quote
Old 01-06-2013, 08:39 AM   #16 (permalink)
rowdie's Avatar
Date registered: Jun 2008
Vehicle: '73 450SL: '81 280SL: 1986 560SL: '84 500SL AMG: 1984 280SL 5 speed (Strassenkröte)
Length of time depends on temperature. IIRC the thermal time switch controls this.
rowdie is offline   Reply With Quote
Old 01-06-2013, 08:46 AM   #17 (permalink)
I have read that the thermal time switch controls that, so I will check that now.... OT, since both of you, Rowdie and Nobby, are here, where does the power supply come from to feed the plug for the ICU? I know it's "off-topic" but I'm working on two cars at once!
Old 01-06-2013, 09:12 AM   #18 (permalink)
rowdie's Avatar
I do not know. I am terrible at reading wiring diagrams. Especially the ones in the on line or CD manual.
Bookmarks
