Differential Removal - Page 2 - Mercedes-Benz Forum
post #11 of 15 (permalink) Old 12-01-2012, 07:48 PM Thread Starter
71_340's Avatar
Date registered: Nov 2012
Vehicle: No MB right now, 2015 F-150 EB , 2008 BMW R1200GS, 2011 Nissan Juke (wife's), 2000 Jeep (Dobie's).
Thanks,
that is the information I needed, almost like a GM differential.
I am originally from Germany and went through a 3 year apprenticeship program at a Unimog dealership (72-75). So I have been working as a mechanic for a long time (on Army stuff since 76). I had well over a 100 different vehicles and pride myself to do all my repairs (except the new electronic stuff). I also had numerous other MB's but the 560SL has to be the most difficult one to work on. Probably because they shoehorned all the S-class mechanics into the small 107 chassis.
If it wasn't for this forum and you guys I would have a really hard time with my SL adventure.
71_340 is offline
post #12 of 15 (permalink) Old 12-01-2012, 08:01 PM
roncallo's Avatar
Date registered: Apr 2005
Vehicle: 1986 560SL with M120 V12 Engine, 1988 560SL Stock
Quoted: 295 Post(s)
Originally Posted by 71_340 View Post
Thanks,
I am originally from Germany and went through a 3 year apprenticeship program at a Unimog dealership (72-75). So I have been working as a mechanic for a long time (on Army stuff since 76). I had well over a 100 different vehicles and pride myself to do all my repairs (except the new electronic stuff). I also had numerous other MB's but the 560SL has to be the most difficult one to work on. Probably becuase they shoehorned all the S-class mechanics into the small 107 chassis.
Its exactly like a GM. While you are in there you may want to consider replacing those clutch friction disks. That gets a bit pricy but you are there.
roncallo is offline
post #13 of 15 (permalink) Old 12-01-2012, 08:20 PM
Date registered: Dec 2012
Vehicle: 87 560SL, 71 280SL euro, 74 VW Ghia, 78 280Z Black Pearl, 78 280Z, 04 Corolla, 07 Odyssey, 94 Prizm
Hello. I hope these pdf files help you.
http://www.startekinfo.com/StarTek/o...hassis/B35.pdf
http://www.startekinfo.com/StarTek/o...sis/35-010.pdf
Let me know if these help you.
OzzyQ80 is offline
post #14 of 15 (permalink) Old 12-01-2012, 08:55 PM Thread Starter
71_340's Avatar
PDF file
I found those two in the manual I downloaded.
The only thing I need now is the bearing preload torque value when tightening down the pinion nut. If I can't get the info I guess I'll go with about 15-20 inch pounds....pretty standard value across the board.
Just ordered the three seals and new pinion nut from partsgeek.com, the seals are OEM only and are not available from the local parts stores. Might as well replace them while I have the differential out.
I will leave the friction discs alone, I already spent enough money in the past three weeks on preventive maintenance and repairs.
71_340 is offline
post #15 of 15 (permalink) Old 12-01-2012, 09:21 PM
If you haven't disassembled it yet, measure how much turning force is needed and use that as a reference. That is what I do if I can't find any info. I check my torques with my torque wrench in newton meters. That is the only thing I can think of at this moment. Hope all goes well.
OzzyQ80 is offline
