Fuel Accumulator - Page 5 - Benzworld.org - Mercedes-Benz Discussion Forum
» Auto Insurance
» Featured Product
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Roadster Forums > R/C107 SL/SLC Class
Old 11-19-2012, 01:48 PM   #41 (permalink)
Date registered: Nov 2011
Vehicle: 1985 380sl
Other then yours, my cap. Do you agree that the short niple goes into the pump? Thats what the digram and picture show. If thats correct it should not be leaking out the end, right? So it was insert wrong (to stop leaking) and I need to find a metal end cap? The truth will come when I recive my checkvalve in mail. I bet the new checkvalve inserted like pictures show the end will not leak.
littlered380sl is offline   Reply With Quote
Old 11-19-2012, 04:02 PM   #42 (permalink)
rowdie's Avatar
Date registered: Jun 2008
Vehicle: '73 450SL: '81 280SL: 1986 560SL: '84 500SL AMG: 1984 280SL 5 speed (Strassenkröte)
The check valve only fits in one direction. FP, washer, check valve (short end), washer, banjo fitting, washer, metal cap. No plastic.
rowdie is offline   Reply With Quote
Old 11-19-2012, 04:10 PM   #43 (permalink)
petesmga's Avatar
Date registered: Aug 2009
Vehicle: 1979 280sl 4 sp w/ac 1984 280sl auto w/ac 1998 volvo xc/70
Maybe the plastic cap came as packing protection to protect the threads.
petesmga is offline   Reply With Quote
Old 11-19-2012, 10:56 PM   #44 (permalink)
yashka26's Avatar
Date registered: Aug 2010
Vehicle: 1988 560SL Lorinser LO's
Post some pics.
yashka26 is offline   Reply With Quote
Old 11-20-2012, 01:05 AM   #45 (permalink)
yka
yka's Avatar
Date registered: Dec 2008
Vehicle: US spec MB560SL 1986, Audi A4 2pcs, Ford Taunus 1964 17M and 2.0 1975
Send a message via Skype™ to yka
Interesting, I can not understand how the OEM check valve can be assembled wrong way - the IN/OUT threads should be different sizes (?)
Yka
Suolahti Suolahtelaisille! .
yka is offline   Reply With Quote
Old 11-20-2012, 09:16 AM   #46 (permalink)
Vehicle: 1985 380sl
Yes, wierd. I'm out of town for thanksgiving. I'll post pictures when I get backe home Mon/Tue. Have a good thanskgiving all.
Old 11-20-2012, 10:11 AM   #47 (permalink)
yashka26's Avatar
Your pump doesn't look oem, and if its not taking an oem check valve, I would replace it.
Potential problem:
Fuel psi's
You can't replace check valve
Check valve is mounted incorrectly
You only have one of them, shouldn't be too bad $$.
Old 11-20-2012, 02:07 PM   #48 (permalink)
Vehicle: 1985 380sl
Right, from everything ive seen here the valve was in backwards. Got new checkvalce today at other home. Will check it out Mon/Tues. Will also post picture of new and old checkvalve. Recived info on pump pressure but it was in "bars"? Anyone know what psi is, thought I read 9psi?
Old 11-20-2012, 05:50 PM   #49 (permalink)
nobby's Avatar
Date registered: Feb 2005
Vehicle: '83 280 SL 5 speed - The PIG
Google is your friend.
Go to a bar to psi conversion site.
An eye for an eye only makes the whole world blind.
nobby is offline   Reply With Quote
Old 11-25-2012, 07:40 PM   #50 (permalink)
Vehicle: 1985 380sl
Good one, pickup extra pump in tucson, PSI max at 125psi. Wow, I'm surprised at that output.
Bookmarks
