My 76 450slc usually starts with no problem from cold start. However, there are occassions where it won't start initially, then when I try to start again
immediately there's nothing. If I wait a few minutes (approx. 2-3) it will start. Has anyone ever experience this and if so what was the fix?
Vehicle: US spec MB560SL 1986, Audi A4 2pcs, Ford Taunus 1964 17M and 2.0 1975
The cold start valve explains the easy cold start - It makes the mixture richer for the cold start.
The warm and hot starts are most probaply with poor/weak mixtures. Check air leaks and if not any check the air measure plate home and basic positions. If air plate has too much free play it does not press the FD plunger before strong engine running.
I will do some more testing on this issue and try to give a better description of the problem. Just installed new plugs, wires, filter, and distributor cap. I will see if this helps.
So how did you solve the problem? I had a scare when I stopped for a snack and the starter just clicked. Any ideas?
My starter issue was due to the nuts on the starter not tightened properly.
Once we tightened the starter and the solenoid nuts all was well. I hope your
problem is as simple as that.
