1985 500SL Transmission shifting problems - Mercedes-Benz Forum
post #1 of 13 (permalink) Old 02-29-2012, 06:15 PM Thread Starter
Date registered: Feb 2012
Vehicle: 1985 Mercedes 500SL
I recently purchased a 1985 500SL.
I is going to need some work but a the moment my biggest problem is the Automatic transmission.
It had an intermittent issue with not being able to put the shifter in the Reverse, Park and in the 2dn gear position but other wise it appeared to be shifting fine.
I had the gear shift bushings replaced which at first appeared to address the issue. Also transmission fluid was added to bring it to the correct level.
Then when I was driving the car the other day it suddenly would not shift gears anymore accept at very high RPMs. The only way the car now shifts gears is if I rev the car upto 4500 rpm. I have since stopped driving the car and the issue of not being able to put the car in Park or reverse has returned as well.
I noticed that the tranmission cooling hoses connected to the radiator are leaking transmission fluid but am not sure if that may be related to the shifting issue.
I am wondering if this is an indicator of a serious transmission problem or if it is something that could be fixed without dropping the transmission.
I have gone ahead and ordered a new modulator, cooling hoses and transmission filter but am concerned the replacing those items will not address the problem and I was wondering if anyone has some suggestions,
Thanks,
Brauny is offline
post #2 of 13 (permalink) Old 03-01-2012, 03:50 AM
Date registered: Sep 2010
Vehicle: '85 380SL (155Kmiles), '82 240D stick, '80 300SD, '77 240D, '89 BMW 535i, 3 VW Diesels, 2 Triumphs
Sounds like a working pressure issue. Are you sure the fluid level is correct and the filter is clean?
If it has been leaking for awhile and you have not topped up the fluid, yes, that may be the issue.
I had problems getting our 380SL to "go" when I stupidly put only 5 or 6 quarts in it after a filter change....
rs899 is offline
post #3 of 13 (permalink) Old 03-01-2012, 07:08 AM
Bob's Your Uncle!
nobby's Avatar
Date registered: Feb 2005
Vehicle: The PIG -'83 280 SL 5 speed
Quoted: 1578 Post(s)
Thanks,
I think that you are on the right track. These are things that need to be done anyways and will probably cure your problem.
Unknown car? I would change ALL fluids and filters so that I have a benchmark point.
Originally Posted by nobby View Post
ils peuvent aller se faire mettre
www.benzypalooza.com
nobby is offline
post #4 of 13 (permalink) Old 03-01-2012, 10:58 AM
Texas500SL's Avatar
Date registered: Dec 2011
Vehicle: 1984 500SL 000760
I hope your maintence fixes your problem. If your tranny is a ZF auto the ZF tranny is very expensive to rebuild. let us know what the fix is!
Texas500SL is offline
post #5 of 13 (permalink) Old 03-01-2012, 11:17 AM
reno4u2's Avatar
Date registered: Dec 2009
Vehicle: 1988 560SL (California Model)
Quoted: 741 Post(s)
Having a flush and refill along with a new filter cures a lot of ills...not inexpensive to have done but much cheaper than a rebuild.
reno4u2 is offline
post #6 of 13 (permalink) Old 03-01-2012, 12:50 PM Thread Starter
Thanks for the suggestions. The parts have come in. I will follow up once we have flushed the transmission, installed the modulator the filter and hoses. hopefully this will take care of the issues.
Thanks
Brauny is offline
post #7 of 13 (permalink) Old 03-04-2012, 05:01 PM
Date registered: Mar 2012
Transmission jumps when stopping!!
Hi,
I am new to the forum, and will appreciate any assistance.
I have a 2000 C230 Kompressor and it has 155,000 miles. Today when I was driving home I went to stop at a red light (was going about 40-45 mphs) and when I applied the brakes I felt a jump when the transmission downshifted at about 15-20 mphs.
Note: Transmission shifts fine during driving.
Thanks for all the help!!!!
toni03103 is offline
post #8 of 13 (permalink) Old 03-04-2012, 05:03 PM
Werner W's Avatar
Date registered: Aug 2008
Vehicle: 1985 500SL 118K (Horst)
Quoted: 48 Post(s)
So what is a ZF tranny?
Werner W is offline
post #9 of 13 (permalink) Old 03-04-2012, 05:11 PM
rowdie's Avatar
Date registered: Jun 2008
Vehicle: 1986 560SL: '84 500SL: '84 280SL 5 speed: other 107s
Quoted: 102 Post(s)
Originally Posted by toni03103 View Post
Hi,
Wrong forum. This one deals with the 1971-1989 W107 models.
rowdie is offline
post #10 of 13 (permalink) Old 03-04-2012, 06:18 PM
It Is What It Is, Dude
isthisdave's Avatar
Date registered: Mar 2006
Vehicle: 1978 107.024 RIP
Quoted: 95 Post(s)
Hi,
Welcome to BenzWorld, toni.
You need to post your question here.
isthisdave is offline
91 500SL - Transmission is Confused shifting from 3 to 4 iresfrank R129 SL-Class 17 02-13-2012 06:08 PM
1992 500SL Strange Shifting 722.3 Transmission RoadKing R129 SL-Class 13 04-01-2011 02:46 PM
1985 300SD W126 shifting to reverse hesitation automatic transmission ? rkpatt W126 S,SE,SEC,SEL,SD,SDL Class 2 08-10-2010 02:00 PM
1985 300SD transmission shifting issues graydonblair W126 S,SE,SEC,SEL,SD,SDL Class 28 05-19-2010 09:07 PM
91 500SL - Problems Shifting From 2 to 3 jcb928 R129 SL-Class 3 05-12-2008 03:16 PM
