1987 560sl U joint - Mercedes-Benz Forum
post #1 of 12 (permalink) Old 02-22-2012, 10:27 AM Thread Starter
Date registered: Sep 2011
Vehicle: 1987 560SL
1987 560sl U joint
I am having trouble finding a U joint for my 87 560sl. I have the new flex discs and carrier bearing but when I took out the shaft yesterday and found the u joint was not that smooth as I think it should be. I also found that the pinion flange was in bad shape, it seems that the previous owner did not care about the vibration that was coming from the car. When I bought the car it was not running so I had no idea until I got it on the road last week. I think I can get the flange from the locale pick and pull but the u joint is not showing up anywhere. Also how hard will it be to change since they staked it in from the factory.
Thanks
Angelo
32coop is offline
post #2 of 12 (permalink) Old 02-22-2012, 10:36 AM
Bob's Your Uncle!
nobby's Avatar
Date registered: Feb 2005
Vehicle: The PIG -'83 280 SL 5 speed
Quoted: 1612 Post(s)
Thanks
Angelo
Fellow member Roncallo has replaced one.
But if you are replacing the flange and the u-joint, a driveshaft shop might be a good idea so you can get it balanced after.
The hanger bearing is a usual suspect for vibration, as well.
Originally Posted by nobby View Post
ils peuvent aller se faire mettre
www.benzypalooza.com
nobby is offline
post #3 of 12 (permalink) Old 02-22-2012, 12:14 PM
Bob's Your Uncle!
nobby's Avatar
I just returned from talking to the lead mechanic at my MB dealer.
He says that MB does not sell the u joint....the assembly needs to be purchased.
He replaced a u joint by using a die grinder to gring off the "pinched" points, pressed the u- joint out, went to Carquest where they have a u-joint chart with all the pertinent info, bought the correct u joint, pressed it back in and then used his mig to put a couple of weld drops on the edge to replicate the "pinched" points on the edge.
nobby is offline
post #4 of 12 (permalink) Old 02-22-2012, 04:35 PM
roncallo's Avatar
Date registered: Apr 2005
Vehicle: 1986 560SL with M120 V12 Engine, 1988 560SL Stock
Quoted: 295 Post(s)
I got my U joint from Parts America no longer in business. I staked mine back in but you need to be careful to hold center. Good luck finding one. I would be very cautious about welding. Some bearing materials change properties at around 300° F. Grease goes on fire and becomes worthless at ~ 400° F.
If your flanges are also bad perhaps you should just consider a rebuilt shaft for like $200.00 - $300.00 with new flex couplings. By the way genuine MB couplings are over $200 for two.
This is the only one I could find. A bit pricy
http://www.jcwhitney.com/omix-univer...erid=c3671u0j1
roncallo is offline
post #5 of 12 (permalink) Old 02-23-2012, 12:49 AM Thread Starter
Vehicle: 1987 560SL
Yes I thought about taking a die grinder to it , or just leave it cause it is not that bad. But as much of a pain in the ass that it is to do this job I figured while I am there I would just change them. The flanges on the shaft are fine the one that is bad is the one mounted to the pinion.
32coop is offline
post #6 of 12 (permalink) Old 02-23-2012, 03:18 AM
Date registered: Oct 2006
Vehicle: '88 560SL, '15.5 Volvo XC60, '13 Audi S5, '53 MG TD, '35 Ford Cpe, '57 MG ZB Magnette
Quoted: 2 Post(s)
I used these guys years ago for a BMW driveshaft and was very happy with the service and quality.
Driveline Service of Portland
lkfoster is offline
post #7 of 12 (permalink) Old 02-23-2012, 04:50 AM
roncallo's Avatar
Quoted: 295 Post(s)
The pinion flange on the trans and diff is available separately from MB. They should also be readily available in junk yards as complete diffs are hard to sell and there are plenty of bad transmissions to pull from.
roncallo is offline
post #8 of 12 (permalink) Old 02-23-2012, 07:14 AM
Bob's Your Uncle!
nobby's Avatar
Agreed. The "drop" should be small and on the lip of the driveshaft. Just to prevent the u-joint from floating.
nobby is offline
post #9 of 12 (permalink) Old 02-23-2012, 08:16 PM Thread Starter
Vehicle: 1987 560SL
Went to the pick and pull today found a 75 450sl got uder the car pulled the drive shaft out to get the flange off only to find that the nut is different so now I have to get one of those special sockets. I tried some other Mercedes but the flange was not the same.
32coop is offline
post #10 of 12 (permalink) Old 02-24-2012, 03:33 AM
roncallo's Avatar
Quoted: 295 Post(s)
I have the special socket available on the tool loan program for the 722.6 trans. Not sure its the same but honestly Ive been able to use a standard 12 point deep socket prior to getting the special socket. just need to hold it on square.
roncallo is offline
1987 560sl smiked1 For Sale/Wanted/Trade/Giveaway 5 01-10-2015 09:09 AM
1987 560sl WTF? $27,000??? jplinville R/C107 SL/SLC Class 1 08-28-2010 04:12 PM
FS: 1987 560SL (NC) Beemer Guy For Sale/Wanted/Trade/Giveaway 2 12-09-2009 08:38 AM
'86 560SL lower ball joint replacement vwclevenger R/C107 SL/SLC Class 1 09-26-2009 03:10 PM
1987 560SL Fitment Guest (MBNZ) The Discount Tire Direct Tire, Wheel, Brake & Suspension 1 02-27-2002 12:16 AM
