Still have no heat problem with 80 450SL - Mercedes-Benz Forum
post #1 of 20 (permalink) Old 02-10-2012, 07:29 AM Thread Starter
Date registered: Sep 2011
Vehicle: 1980 450SL
Lost heat in 80 450SL quite a while ago. Changed out thermostat, did not help. Ordered new Auxiliary heat pump, does that usually solve the problem?
Can I change it out myself?
Bud in Stone Mountain is offline
post #2 of 20 (permalink) Old 02-10-2012, 10:03 AM
Logikal's Avatar
Date registered: Dec 2011
Vehicle: 1974 450SL; 2009 CLS550
More details needed, is the blower motor working properly? Do you know if the heater core is blocked or is it sufficiently flowing? Also do you have slide controls or the prone to break ACCII controls?
Logikal is offline
post #3 of 20 (permalink) Old 02-10-2012, 10:06 AM
Forum Administrator RC Colas® & Moon Pies®
Digmenow's Avatar
Date registered: Oct 2006
Vehicle: 1981 380SL 151K: 2001 E320 4Matic Estate 147K: 2008 E350 Sport 4Matic 120K: 2005 S500 116K
Quoted: 1471 Post(s)
My money is on your climate control servo. Do any of the heater hoses under the hood get hot after the car warms up?
Here's a thread without resolution yet (Rory, anything?) but you might find an answer along the way.
1978 450 ACCII Investigation/Repairs
Quis custodiet ipsos custodes?
Digmenow is online now
post #4 of 20 (permalink) Old 02-10-2012, 11:59 AM
One of the BW Old Guard
Ears's Avatar
Date registered: Aug 2004
Vehicle: 1988 560Sl
Quoted: 258 Post(s)
Assuming his '80 has the ACCII system, I concur... Damned Servo! Servo motor likely frozen, therefore amp also likely Tango Uniform. Consider Unwired Tools (brand) digital conversion if servo is found to be FUBAR. AUX pump easy to change, but likely not the culprit as heat will flow without it.
You can remove the top of the servo easily enough, and watch for movement in the unit when switching heating/cooling modes... Check the EGv107 for info on the ACCII climate system, or the FSM.
Best of luck!
RM Smith www.rmsmithco.com
Where is it again that we are going... And why are we in a handbasket?
Ears is offline
post #5 of 20 (permalink) Old 02-10-2012, 02:25 PM
Digmenow's Avatar
I loved my UT digital conversion for the week that it worked until the blower seized.
post #6 of 20 (permalink) Old 02-10-2012, 02:34 PM
rowdie's Avatar
Date registered: Jun 2008
Vehicle: 1986 560SL: '84 500SL: '84 280SL 5 speed: other 107s
Quoted: 97 Post(s)
Do you think that caused the failure?
rowdie is offline
post #7 of 20 (permalink) Old 02-10-2012, 03:24 PM Thread Starter
Vehicle: 1980 450SL
Motor works fine, controls change between top window vents and dash vents/floor vents just fine. Just temp is cold.
80 has the ACCII controls. not the slide controls.
post #8 of 20 (permalink) Old 02-10-2012, 03:25 PM Thread Starter
Vehicle: 1980 450SL
yes, the heater hoses do warm up.
post #9 of 20 (permalink) Old 02-10-2012, 03:32 PM
Digmenow's Avatar
I can't see how but there was an occasional hamster wheel squeak from time to time last summer so it may have been heading that way all along.
Take a good flashlight and look around the servo. It's the part with the big trapezoidal plastic top. I'm betting you'll see a crack in the side of it like the one in this picture running top to bottom on the middle, can shaped portion.
I'd place confidence that it's the servo at around 94%. Also, as ears said above, the amplifier is most likely burned up as well. It lives inside the car, way up on the firewall behind the glove box.
I employed my brother-in-law who is an auto technician to do the heavy lifting and the Unwired Tools digital unit was installed and operational in about 3 hours.
post #10 of 20 (permalink) Old 02-10-2012, 03:33 PM Thread Starter
Vehicle: 1980 450SL
Installed the aux pump, but havent started car yet. If I take off the top of the servo *(how to do it?_) what do I look for?
I saw the UT conversion, but price scared me unless I tried all the other alternatives.
    '1972 450SL dashboard heat/ac vent' oldride R/C107 SL/SLC Class 2 08-20-2009 08:09 PM
    No Heat 78 450SL newbenzy R/C107 SL/SLC Class 2 09-28-2006 04:06 PM
    78 450SL Heat always on jlon R/C107 SL/SLC Class 0 07-27-2004 07:39 PM
    NO HEAT! Help 79 450sl Guest (MBNZ) R/C107 SL/SLC Class 0 04-26-2001 08:43 AM
    NO HEAT! Help 79 450sl Guest (MBNZ) General Mercedes-Benz 0 04-26-2001 08:43 AM
