Hello,
Hoping for some hints where to looks.
My 1981 380SL has been in the renovation mode for the past few months. Been several weeks since it was last started, but it was a regular starting car with no issues at that time.
Since the last time it was running, I've taken out the instrument panel and had the speedo repair; also I removed the linkage and replaced the bushings. The interior is all out right now (seats, carpets) plus I changed all shocks, drag link.
So yesterday I wanted to start it up to get it running and work on the no-heat issue. Plugged in the instrument panel and turn the ignition. The fuel gauge reacts, the buzzer sounds, the clock ticks, but the engine does not turn over. Nothing, no solenoid click, no starter engaging; just nothing.
Thought maybe I have the linkage in wrong and it might be in gear, but I removed the linkage and manually clicked the transmission "bolt" connector through all the gear positions and tried starting each time; still nothing. As far as I figured, two spots (park and neutral) should have allowed it to start.
Put jumper cables on the battery from my other car, still nothing, so not a battery issue.
How/where is no-start wired for transmission "in gear" check?
Checked the fuses; all good.
Thoughts what to look at now?
Appreciate comments.
Cheers,
Eric
Cheers,
Eric
