450SL odometer repair - Mercedes-Benz Forum
post #1 of 13 (permalink) Old 10-31-2011, 02:06 PM Thread Starter
Date registered: May 2010
Vehicle: 1979 450SL UK spec
Quoted: 46 Post(s)
I managed to get a 1980 dash pod from ebay to repair my non functional odometer. I thought I would be able to strip it down and swap the broken cog, but it looks like I will have to pull off the speedo needle to strip down any further. Has anyone taken a strip down any further?
The alternative is to swap over the entire module, which will lead to the incorrect mileage being shown which would cause a problem at the MOT. Since I have never clocked a car before, if I stick on an electric drill to take it up to 150,000 miles, am I likely to do any damage if winding at a relatively high speed?
RaceDiagnostics is online now
post #2 of 13 (permalink) Old 10-31-2011, 02:21 PM
Date registered: Sep 2008
Vehicle: 1975 450SL
Quoted: 15 Post(s)
New replacement gears are available on the net for a very reasonable amount. Check Nobby's thread in the EGv107. I suspect that the expense of international shipping would be nominal, if you can't find them semi-locally. New gears will include the peace of mind of knowing that old ones may fail at any time.
Good Luck,
Scott
RadioTek is offline
post #3 of 13 (permalink) Old 10-31-2011, 02:25 PM
Bob's Your Uncle!
nobby's Avatar
Date registered: Feb 2005
Vehicle: The PIG -'83 280 SL 5 speed
Quoted: 1586 Post(s)
I have not done it....but I think you can take the odo apart (knock out the pin) and set the numbers to whatever. Take that with a grain of salt.
Originally Posted by nobby View Post
ils peuvent aller se faire mettre
www.benzypalooza.com
nobby is offline
post #4 of 13 (permalink) Old 10-31-2011, 02:27 PM
rowdie's Avatar
Date registered: Jun 2008
Vehicle: 1986 560SL: '84 500SL: '84 280SL 5 speed: other 107s
Quoted: 102 Post(s)
Worth a call to MOT to see if there are some forms and procedures for replacing the unit. There probably are because this would be a common problem with older vehicles.
rowdie is offline
post #5 of 13 (permalink) Old 10-31-2011, 02:41 PM Thread Starter
Quoted: 46 Post(s)
I found out how to change the odo in nobby's thread without much further dissasembly, here http://www.benzworld.org/forums/w123...ml#post3884939
post #6 of 13 (permalink) Old 10-31-2011, 02:48 PM
Date registered: Apr 2006
Vehicle: 1983 380SL, 2000 S430, 1991 420SEL (retired) - RHD
Quoted: 235 Post(s)
I recall reading about replacing cogs on an odometer, but can't remember where! I was looking because I have a "clunking" trip meter on my 126 and it's still on my to do list. After 300,000 kms I'm not too worried about mileage inaccuracy. If I can find the post I'll come back. Meantime you have little to lose by pulling the broken one apart and taking nice pics for the rest of us! How's that for selfish advice! Good luck.
Aussiemerc is offline
post #7 of 13 (permalink) Old 10-31-2011, 03:10 PM Thread Starter
Quoted: 46 Post(s)
Got it sorted!
post #8 of 13 (permalink) Old 10-31-2011, 05:04 PM
the lurker's Avatar
Date registered: Aug 2011
Vehicle: 1976 450 slc
Quoted: 4 Post(s)
if odo & trip dont work, then its one of the two plastic gear/ worm drives.
If its just your trip then its 99% the small gear between the two cylinders that breaks a tooth when you reset the trip while the car is still moving
the lurker
ID:	406692   Click image for larger version
the lurker is offline
post #9 of 13 (permalink) Old 11-01-2011, 04:15 AM Thread Starter
Quoted: 46 Post(s)
Its both my odo and trip that have stopped, I'll pull the old pod out of the car tonight and post up the pictures.
post #10 of 13 (permalink) Old 11-01-2011, 02:20 PM Thread Starter
Quoted: 46 Post(s)
OK, I now discovered the root cause of the stopped odo and trip, the replacement dash has the same issue but to a lesser extent.
The problem is with a metal gear slipping on the main shaft. It is the large grey one at the end of the digits on the odo. It needs to be glued to the shaft.
I found a fix for it here Mercedes Benz 107 SL SLC Roadster Odometer Repair tricky to do but not impossible.
The good news is I will be able to fix both and resell one on ebay.
Need to repair odometer. mrlightrail W126 S,SE,SEC,SEL,SD,SDL Class 10 05-04-2012 04:52 AM
Odometer Repair - maybe not.... archham W123 E,CE,D,CD,TD,TE Class 12 04-26-2011 10:46 AM
Odometer repair mr.metalgear W126 S,SE,SEC,SEL,SD,SDL Class 6 11-19-2010 05:56 PM
Odometer repair 420 SE W126 S,SE,SEC,SEL,SD,SDL Class 8 05-09-2009 05:59 PM
Odometer Repair sali W126 S,SE,SEC,SEL,SD,SDL Class 3 06-11-2004 06:06 PM
