oil filter spin on adapter - Mercedes-Benz Forum
post #1 of 35 (permalink) Old 08-16-2011, 06:18 PM Thread Starter
Date registered: Dec 2007
any body know if a spin on adapter for oil filter is available for a 74 450 sl? I know there is one for the 190 series I have a similar adapter for my MGA and it works well.
rsanders is offline
post #2 of 35 (permalink) Old 08-16-2011, 06:33 PM
abiby's Avatar
Date registered: Jul 2008
Vehicle: 82 380SL 96 SL500 03 SL500
Quoted: 264 Post(s)
Best info I have is that there isn't.
Alan
If it doesn't fit, force it.
If it breaks, it needed replacing anyhow.
abiby is offline
post #3 of 35 (permalink) Old 08-16-2011, 07:02 PM
rowdie's Avatar
Date registered: Jun 2008
Vehicle: 1986 560SL: '84 500SL: '84 280SL 5 speed: other 107s
Quoted: 102 Post(s)
I don't see the need for one. Spin on filters can be a PITA.
Over three years here and you still have not filled out your profile?
rowdie is offline
post #4 of 35 (permalink) Old 08-16-2011, 07:05 PM
GlueckAuf's Avatar
Date registered: Sep 2009
Vehicle: 1987 Mercedes-Benz 560 SL
None that I've heard of, and folks on this forum ask about such from time to time. The replaceable-element-in-a-permanent-can approach is a bit messier to change, so I can understand the appeal of converting to a spin-on.
Actually I prefer the R107's factory set-up since, unlike many other Benz engines, it hangs down, probably because of space limitations. But with this orientation, gravity helps the canister capture and hold any heavy sediment. This way I can readily see any big chunks the filter might catch between changes rather than allow it to hide in the bottom of the upright style canister found on other Mercedes models with a little more room in the engine bay.
Good road,
GlueckAuf
Sterling Heights, MI
1987 Mercedes-Benz 560 SL Benzedrine
2002 Volvo S80 T6
2004 Litespeed Vortex/Campagnolo Record
GlueckAuf is offline
post #5 of 35 (permalink) Old 08-16-2011, 09:32 PM
Djenka018's Avatar
Date registered: Jan 2005
Vehicle: '80 450SLC Afro RHD Ikonengold
Quoted: 70 Post(s)
Perhaps having a magnet straped on there...?
I think I saw a pic of what looked like M117 with filter canister upright...
Vitamin C for SL... the SLC
Djenka018 is online now
post #6 of 35 (permalink) Old 08-17-2011, 05:40 AM
strife2's Avatar
Date registered: Jul 2004
Vehicle: 560SL,380SL
Quoted: 52 Post(s)
When the 116/117 is installed in a W126, the pedestal and the oil "can" are upright for space reasons, I think. So if you are swapping an engine from a 126, this and the oil pan are two things that have to be swapped from the W107 engine.
"Facing down" is probably better, because then you can easily fill it up to a degree so that the engine gets oil immediately after an oil filter change.
A few things that make a container like the 107 better than a spin-on might be relative immunity from puncture from rocks/objects (this happens, believe me, I know) and spin-on filters have been known to "pop" on high-performance cars.
And...you can't make a spin-on filter look good...
_________________________
Homebrew MB First Gear Start!
http://juliepalooza.8m.com/sl/mercedes.htm
strife2 is offline
post #7 of 35 (permalink) Old 08-17-2011, 06:32 AM
dugald's Avatar
Date registered: Dec 2006
Vehicle: 1986 560 SL
Quoted: 655 Post(s)
Strife, you have reached new levels in polishing.
dugald is offline
post #8 of 35 (permalink) Old 08-17-2011, 06:35 AM
Djenka018's Avatar
Quoted: 70 Post(s)
I tried once to fill up the bowl with oil... was my last attempt at the same time. Made a huge spill on a new paving. Now, I just soak the filter a bit.
But other than on the chrome look... I totally agree on everything else.
post #9 of 35 (permalink) Old 08-17-2011, 08:20 AM
abiby's Avatar
Quoted: 264 Post(s)
I have no doubt that an adapter for spin-on filters could be machined/fabricated and personally I would prefer dealing with one.
As to whether I'd go to the cost and trouble of installing an adapter.... probably not.
Alan
abiby is offline
post #10 of 35 (permalink) Old 08-17-2011, 08:40 AM
Bob's Your Uncle!
nobby's Avatar
Date registered: Feb 2005
Vehicle: The PIG -'83 280 SL 5 speed
Quoted: 1611 Post(s)
The one job on the Benz I hate is oil changes. Awkward is the word.
A spin on would be nice.
It would, of course, eliminate that spring which is kind of a "plugged filter" safety.
Originally Posted by nobby View Post
ils peuvent aller se faire mettre
www.benzypalooza.com
nobby is offline
Where does the spin-on fuel filter go? danriis W201 190-Class 7 07-18-2011 05:16 PM
question about inline and spin on filter DarkManX4lf W123 E,CE,D,CD,TD,TE Class 5 01-29-2007 02:57 PM
Hollow bolt for spin on fuel filter marshman W123 E,CE,D,CD,TD,TE Class 1 07-12-2005 03:37 PM
primary fuel filter (spin on) banditele W123 E,CE,D,CD,TD,TE Class 30 03-16-2005 11:26 AM
spin on oil filter adapter for M115 engine? Gkase W123 E,CE,D,CD,TD,TE Class 2 05-27-2004 05:10 AM
