Neutral/Park safety switch replacement - Mercedes-Benz Forum
post #1 of 15 (permalink) Old 07-06-2011, 02:24 PM Thread Starter
Date registered: May 2010
Vehicle: 1979 450SL UK spec
Quoted: 30 Post(s)
A few weeks back I was stranded 50 miles from home, the problem turned out to be a faulty NSS switch preventing the car starting.
After initially shorting out the switch to get going, I got round to replacing it tonight. Luckily I had a spare switch from my old 350 engine/gearbox.
Old unit.
Here are the tools I used, 8 and 10mm spanners, socket wrench and a flat headed screw driver for levering.
Front support.
Rear support
Here is the switch on the side of the gearbox, tight access.
Releasing the switch from the shaft with a 10mm socket.
Releasing the bottom fixing bolt 8mm.
Releasing the top bolt 8mm.
Once the bolts were off, the switch could be levered off and the connector was released.
The connecting rod was then released from the stick bush and the entire assemble was removed.
Reassembly was done simply in the reverse order with the replacement switch and link.
RaceDiagnostics is offline
post #2 of 15 (permalink) Old 07-06-2011, 04:25 PM
rowdie's Avatar
Date registered: Jun 2008
Vehicle: 1986 560SL: '84 500SL: '84 280SL 5 speed: other 107s
Quoted: 97 Post(s)
Good post. Not easy to get to the linkage clip under there. Not much on the trans in the EGv 107. Good job.
rowdie is offline
post #3 of 15 (permalink) Old 07-06-2011, 05:28 PM
It Is What It Is, Dude
isthisdave's Avatar
Date registered: Mar 2006
Vehicle: 1978 107.024 RIP
Quoted: 90 Post(s)
Where do you guys think it should go?
There is no trans section in the EGv107, 'cuz I copied the online Service Manual system and there's no trans section in it.
So what about Section 54, electrical, or what?
We do have Drivetrain...
isthisdave is offline
post #4 of 15 (permalink) Old 07-06-2011, 05:57 PM
rowdie's Avatar
Quoted: 97 Post(s)
Drivetrain would be good. Or electrical.
A trans section would be best. I know there have been posts on the modulator valve and trans. mount. Pretty sure someone did a post on trans filter and draining torque converter. My brain has been rattled around the last couple of days bouncing in a tractor mowing and raking hay.
rowdie is offline
post #5 of 15 (permalink) Old 07-06-2011, 06:51 PM
isthisdave's Avatar
Quoted: 90 Post(s)
41 is Propeller Shaft in the SM. I had called it Drivetrain, we'll add Transmission.
And near half of 'em are RD's!
Added 7/6/2011
post #6 of 15 (permalink) Old 07-07-2011, 03:49 AM
3547fl's Avatar
Date registered: Nov 2009
Vehicle: 1989 560SL
Quoted: 35 Post(s)
A little off topic. But when I changed out the transmission in my 560. I had a heck of a time finding anything on the transmission. Finally found a PDF file in line that covers it.
Here it is if someone wants to put it somewhere.
Well it's too big to upload, if someone wants to e-mail me for it you can have it.
1951 Oldsmobile Restoration Blog: http://51olds98.blogspot.com/
3547fl is offline
post #7 of 15 (permalink) Old 11-11-2011, 07:22 PM
riccarr's Avatar
Date registered: Jun 2011
Vehicle: 1981 380SL
Hello,
I'm currently wrestling with symptoms of this very same issue (no start). I just replaced the bushing on my linkage. http://www.benzworld.org/forums/r-c1...ml#post4969390
My car is a 1981 380SL. Looking at your pictures, the unit your calling the NSS, where the linkage connects onto the "stud" from the unit. I have that same unit, however what perplexes me is that online pictures of the NSS are not that.
Example: Mercedes® Neutral Safety Switch, 107/123/124/126/140/202/210 chassis - Mercedes Parts and Accessories
This part I do have on my transmission; is it located right beside where the linkage assembly your showing was removed from.
riccarr is offline
post #8 of 15 (permalink) Old 11-11-2011, 07:28 PM
One of the BW Old Guard
Ears's Avatar
Date registered: Aug 2004
Vehicle: 1988 560Sl
Quoted: 257 Post(s)
Mercedes® Neutral Safety Switch, 107/123 Chassis - Mercedes Parts and Accessories
Look a little deeper on the performance products website... rarely do I rely on pics from a parts house...
RM Smith www.rmsmithco.com
Where is it again that we are going... And why are we in a handbasket?
Ears is offline
post #9 of 15 (permalink) Old 11-11-2011, 07:38 PM
riccarr's Avatar
Vehicle: 1981 380SL
That part does not fit the 380SL; the one I linked to does, so there must be a difference between the car of the OP and my 380.
riccarr is offline
post #10 of 15 (permalink) Old 11-11-2011, 07:44 PM
Ears's Avatar
Vehicle: 1988 560Sl
Quoted: 257 Post(s)
bear in mind, he was working on a 450, so differences could easily exist. I understood you to say yours was "like" his, so I pointed you in the direction of what matched RD's switch.
I'd recommend you shop elsewhere, or confirm part number. ...or you can order from performance products, an otherwise reputable parts house (in this case something is amiss, either the picture or part fitment).
Better yet, contact Mercedes Parts, Mercedes-Benz Parts for the part... not listed on his online catalog, but online only has a portion of what he has available. Then there is always the dealer...
Ears is offline
    neutral safety switch hankG. General Mercedes-Benz 0 03-24-2010 05:41 PM
    Neutral Safety Switch stout W124 E,CE,D,TD Class 1 11-27-2008 08:27 PM
    Neutral Safety Switch Replacement jikky54 W126 S,SE,SEC,SEL,SD,SDL Class 1 03-29-2008 09:22 PM
    Neutral Safety Switch/Backup Light Switch SC Surfer W123 E,CE,D,CD,TD,TE Class 13 01-18-2008 01:45 PM
    Neutral Safety Switch Chupper W124 E,CE,D,TD Class 1 01-11-2004 03:33 PM
