Rattle / Knock in the rear end 85 380SL - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 06-26-2011, 10:40 PM Thread Starter
dcrews's Avatar
Date registered: May 2010
Vehicle: 1985 380SL
I finally discovered the source of the noise coming from underneath the rear of my car at low speeds while traveling over uneven ground. The rear sway bar/torsion bar is not connected to anything on the passenger side of the car at the end near the tire. The drivers side seems to be connected to a verticle rod coming off of the top of the axle but it slides freely with up and down movement. I dont think this is supposed to do this.
I have misplaced my repair manual, but would appreciate any help in determining if the right side end of the torsion bar should be connected to a verticle bar the same as the left side is. I haven't had time to jack up the car at this point but i think i am missing a part or something has broken off.
dcrews is offline
post #2 of 7 (permalink) Old 06-26-2011, 10:52 PM
rowdie's Avatar
Date registered: Jun 2008
Vehicle: 1986 560SL: '84 500SL: '84 280SL 5 speed: other 107s
Quoted: 96 Post(s)
There is a stabilizer/sway bar link on both sides. Not not rare for one to break or the rubber to wear out..
rowdie is offline
post #3 of 7 (permalink) Old 06-26-2011, 11:04 PM Thread Starter
dcrews's Avatar
Vehicle: 1985 380SL
Thanks Rowdie. it must be broken since it is not there ... would you know if this part is available without going through a dealership?
dcrews is offline
post #4 of 7 (permalink) Old 06-26-2011, 11:11 PM
rowdie's Avatar
Quoted: 96 Post(s)
They are not OEM so I am not sure of the quality. You should replace both. If you order over $50.00 shipping is free.
http://www.autohausaz.com/search/pro...=27@Suspension System&gid=7580@Stabilizer/Sway Bar Link
For some reason the link does not get you to the part. Try searching the site.
rowdie is offline
post #5 of 7 (permalink) Old 06-26-2011, 11:21 PM
Fotografa's Avatar
Date registered: Sep 2007
Vehicle: 500SLC #2624. Black on Black.
Quoted: 15 Post(s)
After having numerous w114's, I could never work out where the sway bar links were on the W107's I've owned.
Now I know, they were only on North American cars...
Life is too short for bad wine or bad cinema.
Fotografa is offline
post #6 of 7 (permalink) Old 06-26-2011, 11:32 PM Thread Starter
dcrews's Avatar
Vehicle: 1985 380SL
Found them.....will be ordering them tomorrow..thanks Again for the help.
dcrews is offline
post #7 of 7 (permalink) Old 06-27-2011, 07:23 PM
Bob's Your Uncle!
nobby's Avatar
Date registered: Feb 2005
Vehicle: The PIG -'83 280 SL 5 speed
Quoted: 1470 Post(s)
Sigh.
Do I need to come over there?
Originally Posted by nobby View Post
ils peuvent aller se faire mettre
www.benzypalooza.com
nobby is offline
    07 sport w/ 6 speed knock/rattle? on start 07Mercedessport W203 C-Class 1 02-03-2011 01:58 PM
    311 cdi. diesel knock / rattle steviep5 W901-905 Sprinter 0 11-20-2010 02:21 AM
    Knock or rattle in cam area any suggestions?? SignalRed W202 C-Class 11 09-08-2010 05:53 PM
    knock from rear end 240D masevich W123 E,CE,D,CD,TD,TE Class 7 12-11-2009 04:45 PM
    380sl hardtop rear glass rattle tbstarr R/C107 SL/SLC Class 2 03-02-2008 08:11 AM
