One of the minor annoyances I've had with the R107 is the dim turn signal indicators that can cause one to inadvertently leave a turn signal on after a lane change. I hate to find I've been one of those apparent AARP candidates who drives for miles, oblivious that his turn signal has been blinking since he entered the Interstate twenty minutes ago.
In bright sunlight, the standard 1.2 watt instrument bulbs are all but washed out. A brighter bulb is needed here.
While brighter, standard incandescent bulbs might be one option to brighten up the turn signal indicators, I'd be afraid the higher heat they generate might do some damage to the plastic instrument cluster if used for an extended period (like if the hazard lights were used while changing a tire.)
LED-powered instrument bulbs looked like a more promising solution, so I ordered a few from SuperBrightLEDs.com, a BenzWorld sponsor. They had the two different types of bulbs needed to replace the left and right turn signal indicator bulbs, and at a price that I thought was very reasonable.
SuperBrightLEDs offers most of their instrument bulbs in two brightness strengths. I opted for the brighter of the two to replace the anemic standard instrumentation bulbs in my 560 SL.
The left bulb I purchased was their high performance, white-light B8.5D-WHP bulb, a bargain at $2.59. This uses the same twist-lock base as the stock OSRAM 2721MF. For the right bulb, I purchased their $2.49 high performance 24-WHP bulb, which is a match for the R107's instrument panel's wedge-base OSRAM 2721 bulb.
The brightness difference between the two types of bulbs was remarkable. As you can see in the bench test photo below with both bulbs wired in parallel at 13 volts, the LED bulb on the left is significantly whiter and brighter than the standard incandescent bulb on the right. It also projects all of its light forward in a 120-degree arc rather than casting it uniformly around it like the conventional bulb. This means more and better-directed light shines toward the turn signal indicator filter than is possible with the standard bulbs. And the LEDs produce almost no heat, so any worries about damaging their plastic confines are relieved.
The new bulbs installed without any significant problems, though both the twist-lock and wedge bases were subtly different from the bulbs they replaced, and a tighter fit into their respective sockets. But with a little patience and care not to apply any untoward pressure on the apparently glued-on LEDs perched atop the bulb bases, they installed without too much trouble.
One caution--test the function of both bulbs before replacing the instrument cluster. LEDs are polarity-dependent, meaning one side of the bulb has to be connected to the positive side and the other to the negative side--otherwise, they do not illuminate.
The improvement is remarkable. Not only are the new bulbs brighter and sharper than the ones they replaced, but their illumination is instant, snapping on and off like a strobe light instead of like an incandescent bulb's rise and fall in brightness.
I haven't tested how well they grab my attention in bright sunlight yet, but I'm confident they'll be a significant improvement. And maybe they'll help spare me from any more of those "senior moments."
Good road,
Good road,
