Fan clutch or no fan clutch, that is the question - Page 4 - Benzworld.org - Mercedes-Benz Discussion Forum
» Auto Insurance
» Featured Product
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Roadster Forums > R/C107 SL/SLC Class
Old 08-05-2010, 12:22 PM   #31 (permalink)
ScottinSoCal's Avatar
Date registered: Aug 2006
Vehicle: 78 450SL, 87 BMW 325iC, 06 Honda Civic Hybrid, 03 Toyota RAV4
Originally Posted by karburn View Post
One post above gave me the idea that the fan should spin freely when the engine is off, regardless of temp.
The fan is thermomechanical, not electrical. Engine running or not doesn't matter, just the temperature. There should be more resistance when hot, less resistance when cool. Try it in both conditions and see how much difference there is. If there isn't any difference, get a new clutch.
When I die, I want to go quietly in my sleep, like Grandpa.
Not screaming, like the people in his car.
Juvenis quod fanaticus nunquam concilio usus quod proditus
ScottinSoCal is offline   Reply With Quote
Old 08-05-2010, 01:22 PM   #32 (permalink)
slik560's Avatar
Date registered: Aug 2007
Vehicle: 1987 560SL / 2003 ML320 / 2006 Mini Cooper S
I think I got it now...thanks. Hope it's an easy DIY. I'll probably use the Behr replacement in lieu of the $$$$$$$$$$ OEM. Thanks for your time.
Kevin
'87 560SL
'03 ML320
slik560 is offline   Reply With Quote
Old 08-06-2010, 02:24 AM   #33 (permalink)
Djenka018's Avatar
Date registered: Jan 2005
Vehicle: '80 450SLC Afro RHD Ikonengold, '77 280SE Aus RHD Milan Brown
So I can take it that none of you here have the fan with the velocity dependant cluch?
Vitamin C for SL... the SLC
Djenka018 is offline   Reply With Quote
Old 08-06-2010, 05:42 AM   #34 (permalink)
Originally Posted by Djenka018 View Post
So I can take it that none of you here have the fan with the velocity dependent clutch?
No, you're the only one.
Old 08-07-2010, 04:50 PM   #35 (permalink)
Lookout1979's Avatar
Date registered: Jul 2009
Vehicle: 1983 Mercedes Benz 380SL, Navy Blue, 1972 Winnebago Mini Winnie (FOR SALE), 96 Dodge Ram150
Send a message via Yahoo to Lookout1979
And this site seems to have everything and maybe be the cheapest:
73 1973 Mercedes 450SL Fan Clutch - Cooling System - ACM - PartsGeek $169.94
Anybody use this "PartsGeek.com" site?
OK. Benzbin.com looks cool (partsbin.com did not) and they've got a fan clutch for about $195 (a little more expensive than PartsGeek.com) Mercedes Parts - Mercedes Benz Parts - Discount Prices - 1973 Mercedes Benz 450SL Fan Clutch
After a few minutes of browsing and finding on BenzBin: - no wiper motor, and - items like "motorcycle cover", I think i like PartsGeek better so far. Time will tell since I've yet to order anything.
My experience w/ partsgeek ended up in horrible customer service (what CS there actually was)... and it's a HUGE hassle if you have to return anything
Lookout1979 is offline   Reply With Quote
Old 08-07-2010, 05:10 PM   #36 (permalink)
rowdie's Avatar
Date registered: Jun 2008
Vehicle: '73 450SL: '81 280SL: 1986 560SL: '84 500SL AMG: 1984 280SL 5 speed (Strassenkröte)
Another NO vote on PartsGeek.
rowdie is offline   Reply With Quote
Old 08-08-2010, 12:24 PM   #37 (permalink)
Fonzi's Avatar
Date registered: Jun 2010
Vehicle: 1973 10704412007016-soon4sale 10702612000478-convertible
Good info. Thank you on the PartsGeek info. I'll be sure to stay away. For now I think Rockcrusher is solving all MY problems. Gotta love this site!
Fonzi is online now   Reply With Quote
Old 08-21-2010, 06:06 PM   #38 (permalink)
slik560's Avatar
Not all fan clutches are created equal
I ordered a replacement fan clutch from Performance Products. When I had the new unit installed (I'll spare you all of the details) I found that the new unit was too short; ie: it put the fan too close to the belts/pulleys. I took it out and disassembled everything [again] and put the old unit and the new side by side. See photo:
The old clutch is on the right. Note the attachment tabs for the fan blade assembly. There is a 5/16" difference. The new unit puts the fan 5/16" closer to the motor, which is just not acceptable. I sent the part back to Performance Products today. VERY dissappointing.
SO....now the choice is to order one from another source and take my chances, or punt and go the flex fan route. I would need to find one that moves enough air for this motor. So far the ones that I see online are good only up to 4L motors.
Old 08-21-2010, 07:28 PM   #39 (permalink)
Fonzi's Avatar
Should have orderd from PartsGeek.
Just kidding!
When I installed the AC belt on mine, I was really thinking that maybe I was going to need to remove my fan. I was just barely able to squeeze in my new AC belt after a lot of patience. I wonder if my fan clutch is a 1/4 inch too short too? Interesting. Thanks for posting!
Old 08-31-2010, 06:50 AM   #40 (permalink)
slik560's Avatar
I was able to get the correct fan clutch from my local MB independent shop at a decent price and it fit perfectly. I cannot believe how much air the thing moves now. I did some long highway drives, each ending with some deliberate stop-n-go driving, and the temp gauge would only go slightly above normal....and then go back down when the car was moving at speed again. I think I have this part of my stalling-while-hot problem fixed.
The downside, if you could call it one, is the noise. The fan now moves so much air that the car sounds like my grandmother's old Hoover vacuum cleaner when accelerating. No kidding. While the sound is reassuring in that I know the radiator and motor are now getting more air, it actually drowns out any exhaust note. So...there is only one viable solution:
MAGNAFLOW! Time to start the exhaust rehab project: Magnaflow cat, delete the stock resonator, new Magnaflow muffler and stainless piping in between. I can't show my face at the next autocross with the car sounding like a turbine, now can I???
Bookmarks
Flex-a-lite electric fan instead of stock fan clutch on 1994 SL320 veyron16 R129 SL Class 16 05-12-2010 02:06 PM
fan clutch question tnez190e W201 190 Class 11 09-10-2009 06:58 PM
Head gasket leveled, New Radiator, new Thermostat, New fan clutch, both Auxiliary fan Workersvillage W124 E,CE,D,TD Class 11 08-10-2008 10:32 PM
Fan Clutch Question KarenV W201 190 Class 53 01-20-2007 03:40 AM
fan clutch question ehizon W140 S-Class 7 02-27-2006 09:42 AM
