Fluid Capacities for 1976 450SL - Mercedes-Benz Forum
post #1 of 13 (permalink) Old 05-25-2010, 09:32 AM Thread Starter
Date registered: May 2010
New to the forum as a new owner of a 1976 450SL with 29,500 miles. Based on replies to my previous post about changing the fluids, I would appreciate if someone can tell me the oil, automatic transmission, and coolant fluid capacities. Also, should I use 10W- 30 or 5W-30 for summer driving in Northeast Pennsylvania. What type and brand of automatic transmission fluid should I use. If there is an easy way to find this info on the forum I would appreciate your help. By the way, I am really enjoying this car! I have found that it is a real head turner wherever I go!
JMNCPA is offline
post #2 of 13 (permalink) Old 05-25-2010, 10:13 AM
ScottinSoCal's Avatar
Date registered: Aug 2006
Vehicle: 2010 Mercury Milan Hybrid, 1993 BMW 325i convertible
Quoted: 17 Post(s)
I use 10W-50 in my car, but it has 170K miles on it without any engine work to speak of, so things are a little more loose than on your car. Even new, though, I'd hesitate to go as low as 5W.
(And even with 170K miles and no engine work, it passes emissions with the same specs as it had when new - these engine are bullet proof)
Something Dexron II compatible.
Sorry, I don't remember capacities off the top of my head, and my idea of an oil change is writing a check to the place that does it for me. For $110, each time I do it, because these things take way more than 5 quarts. And I use Mobil 1 synthetic.
When I die, I want to go quietly in my sleep, like Grandpa.
Not screaming, like the people in his car.
Juvenis quod fanaticus nunquam concilio usus quod proditus
ScottinSoCal is offline
post #3 of 13 (permalink) Old 05-25-2010, 10:31 AM
Bob's Your Uncle!
nobby's Avatar
Date registered: Feb 2005
Vehicle: The PIG -'83 280 SL 5 speed
Quoted: 1615 Post(s)
If you have such a "young" SL can I assume you have the owners manual in the glove box?
Check the last page. Everything is there.
Originally Posted by nobby View Post
ils peuvent aller se faire mettre
www.benzypalooza.com
nobby is offline
post #4 of 13 (permalink) Old 05-25-2010, 02:41 PM
chrisquinn11218's Avatar
Date registered: Apr 2010
Vehicle: 1979 USA Model 450SL 68,000 miles
Consider upgrading your 5 quart oil drain pan. My 79 just took about 8 quarts of oil in my first oil change as owner. I don;t know offhand the trans capacity but you should get the Haynes manual at the very least. It's not a quick spin off spin on oil filter, and the trans torque convertor has its own drain plug separate from the pan ( a great feature likely to missed by someone without knowledge of the car, I'd assume)
79 Mecedes Benz 450 SL
73 Olds Delta 88 Convertible
01 Ford Mustang GT Convertible
95 Ducati 900SS/SP
93 GMC Suburban K1500
chrisquinn11218 is offline
post #5 of 13 (permalink) Old 05-25-2010, 03:23 PM
rowdie's Avatar
Date registered: Jun 2008
Vehicle: 1986 560SL: '84 500SL: '84 280SL 5 speed: other 107s
Quoted: 102 Post(s)
Oil capacity is approx. 8 qts on all 450SLs.
rowdie is offline
post #6 of 13 (permalink) Old 05-25-2010, 04:04 PM
Djenka018's Avatar
Date registered: Jan 2005
Vehicle: '80 450SLC Afro RHD Ikonengold
Quoted: 70 Post(s)
Engine oil: 7.5 litre or ~8 litre if filter changed
5W for permafrost, 10W if mostly frozen
15W for -15°C upwards
20W if never freezes
-20 or -30 if max temp +/- 20°C around freezing point (eg. Canada)
-40 and -50 if max temp above 20°C in warmer season
Optimal multiseason 10W-50 for temps ranging from -20°C to above 30°C
Transmission:
107024/044 with 722.004 transmission (99.99% of the cars): full capacity 8.9 litre (torque converter too), oil change 7.9 litre
Coolant: until full, 15+ litres of antifreeze no less than 30% by vol
Vitamin C for SL... the SLC
Djenka018 is offline
post #7 of 13 (permalink) Old 08-06-2010, 09:42 AM
Date registered: Aug 2010
ARE YOU GOING TO THE CAR SHOW IN ENID OKLAHOMA THIS WEEKEND ?
autojack is offline
post #8 of 13 (permalink) Old 08-06-2010, 09:45 AM
DO YOU KNOW WHAT TYPE TRANSMISSION FLUID MY 1976 450SL USES OR IS DEXTRON 3 OK ?
autojack is offline
post #9 of 13 (permalink) Old 08-06-2010, 09:45 AM
Quoted: 17 Post(s)
WHY? WHO WANTS TO KNOW?
post #10 of 13 (permalink) Old 08-06-2010, 09:56 AM
rowdie's Avatar
Quoted: 102 Post(s)
MY LATE WIFE WAS BORN IN ENID. IT IS A LONG WAY FROM HERE!
Dextron III is what I use.
rowdie is offline
1991 300TE 4Matic Fluid Capacities and Intervals footeking W124 E,CE,D,TD Class 3 04-01-2010 08:30 AM
1976 450sl Distributor mtbennett24 R/C107 SL/SLC Class 10 01-22-2009 12:33 PM
1976 450sl dahappybanana R/C107 SL/SLC Class 11 06-07-2006 12:05 AM
1976 450SL for sale daveskee R/C107 SL/SLC Class 1 06-21-2004 10:51 PM
1976 AMG 450sl Guest (MBNZ) R/C107 SL/SLC Class 0 09-02-2001 04:06 PM
