For your convenience, the installation or removal of the SL steel hard top can be performed at a Mercedes-Benz dealer that has hard top storage facilities. However, either operation can be accomplished without dealer assistance by two persons, if proper care is exercised.
The hard top is secured to the vehicle at five points. Two front bow locks attach the front of the top to the windshield header bar. Two side locks, one behind each door, secure the sides of the top. One rear bow lock secures the locking pin on the rear bow of the top to the vehicle body. Two locking handles are used to engage the front and side locks. They should be kept in the glove compartment when not in use.
_____________________
Removing The Hard Top
Locking handles
(stored in glove compartment)
CAUTION: Lower windows or open both doors before removing hard top. Prepare a clean place to set down the top prior to removing it from the vehicle. Open the flap on the right side of the rear compartment. Disconnect and pullout the plug for the heated rear window. Close the flap.
Disengage the rear bow locking pin by turning the locking lever counter*clockwise to position B. Turn the safety lever to position E.
To disengage the side locks, insert a locking handle into the slot from the front of each lock. Rotate each handle to its rear stop. Remove the locking handles. If the cap on a side lock pops off while the lock is being released, realign it and push down until it snaps into place.
Lower the sun visors and disengage the front bow locks by inserting a locking handle into the slot from the outer side of each lock. Rotate each handle to its inner position. Remove the locking handles.
With one person lifting at each side, carefully raise the rear of the top, removing the locking pin from its attachment point (arrow). Then lift the front of the top, checking to see that the front and side locks are clear of their attachment points. Remove the top by carefully lifting and then carrying it over the rear of the vehicle, ensuring that the rear bow clears the high-mounted stop lamp. Watch that the plug for the heated rear window does not get caught when removing or replacing the hardtop from the vehicle.
To avoid rattles, turn the locking lever clockwise to position A. Return the safety lever to position D.
Locking handles
