Air - Fuel Adjustment Screw Location ?? - Mercedes-Benz Forum
post #1 of 12 (permalink) Old 02-19-2010, 02:43 PM Thread Starter
benzslcworld's Avatar
Date registered: Feb 2009
Vehicle: 1979 450 SLC - Black on Black - 71k miles
1979 450 SLC
Finding this screw has been driving me crazyyyyy!!! I searched this forum and found information stating that it was an allen screw located underneath the air filter housing, under a rubber cap of some sort.... no such luck...
I attached pictures of what I found...The only screw I could locate has a straight screw head and is right in front of the fuel distributor on the intake manifold.
The car is running way too rich, and I need to adjust the air-fuel ratio so I can test the exhaust for the CO level...and then hopefully get it to the right setting.
Anyone who knows where this screw is please reply....many thanks!!
Name:	February 2010 002.jpg
ID:	291868   Click image for larger version
Name:	February 2010 004.jpg
benzslcworld is offline
post #2 of 12 (permalink) Old 02-19-2010, 04:57 PM
Date registered: Aug 2009
Vehicle: '79 450SL
in middle of second picture, looks like a slotted screw. Mine is allen wrench so it may be under the slotted screw. best to make adjustments in 1/4 turn increments. The underside of my air baffle plate was gunked up, removed it and cleaned with solvent.
1968 is offline
post #3 of 12 (permalink) Old 02-19-2010, 09:41 PM Thread Starter
Thanks 1968! Did not realize that it would literally be underneath another screw. What is the size of the allen key you used?
post #4 of 12 (permalink) Old 02-19-2010, 09:51 PM
rowdie's Avatar
Date registered: Jun 2008
Vehicle: 1986 560SL: '84 500SL: '84 280SL 5 speed: other 107s
Quoted: 97 Post(s)
The normal screw takes a 3mm allen or hex inset. I have a feeling that yours has been altered. Try the slotted screw that is there and see if there is any adjustment. Originally there was a plug over the hole and the 3mm screw under it.
rowdie is offline
post #5 of 12 (permalink) Old 02-19-2010, 10:55 PM Thread Starter
hmmm - it must have been altered...since there is no cap. But I was able to unscrew the slotted screw, remove it, and then with a flashlight could see the allen screw inside. I will go grab a 3mm allen key that is long enough to make adjustments. And then do 1/4 turn (counter clockwise) adjustments to lean the mixture...
I attached pictures of the screw I removed and of where I see the allen screw down inside. If does not seem right - please inform. Thanks!
Name:	February 2010 006.jpg
ID:	291948   Click image for larger version
Name:	February 2010 011.jpg
post #6 of 12 (permalink) Old 02-20-2010, 02:24 AM
It Is What It Is, Dude
isthisdave's Avatar
Date registered: Mar 2006
Vehicle: 1978 107.024 RIP
Quoted: 91 Post(s)
The screw you are turning adjusts the sensor plate within the air horn, affecting the A/F mixture at idle only.
The warm up regulator, also called the control pressure regulator is responsible for controlling the A/F ratio at operating rpms and loads above idle.
isthisdave is offline
post #7 of 12 (permalink) Old 02-20-2010, 01:18 PM Thread Starter
So one can adjust the air/fuel mixture at idle by turning the idle mixture adjustment screw, as seen in diagram above (thanks isthisdave for pasting this)
But how does one adjust the warm up regulator to control the air/fuel ratio at operating rpms?
post #8 of 12 (permalink) Old 02-21-2010, 05:23 AM
Date registered: Sep 2008
Vehicle: 82 380 SL ; 78 450 SLC ; 84 BMW 533i
There is a lot of information in the encyclopedia Germanica on the theory of operation of CIS fuel injection which you need to read, it will help you understand the WUR, systems pressures, AFR adjustments, FD etc in some pretty good detail.
It's a sticky at the top of the page.
But if you're running that rich you might want to make sure you have no vacuum leaks before adjusting the AFR.
romankrzy is offline
post #9 of 12 (permalink) Old 09-11-2011, 12:04 AM
Date registered: Sep 2011
Vehicle: 1981 380sl, 1972 corvette, KZ kaffe bike
Smile Anyone know the thread size
anyone know the thread size of the 3mm hex screw or a place where i can pick up one? my car does not have one for a strange reason. 1981 380sl
starbucks is offline
post #10 of 12 (permalink) Old 09-11-2011, 02:27 AM
Date registered: Oct 2006
Vehicle: '88 560SL, '15.5 Volvo XC60, '13 Audi S5, '53 MG TD, '35 Ford Cpe, '57 MG ZB Magnette
When adjusting the 3mm screw do not rev the engine. If you do the metering plate tries to rise up binding your allen wrench.
lkfoster is offline
    Air/Fuel Mixture adjustment HELP!!! blaydrunner W201 190-Class 10 01-06-2016 07:18 AM
    Air/Fuel Mixture Screw Setting on a 90 - 300TE (M103 engine) Stickman W124 E,CE,D,TD Class 6 11-27-2011 12:10 PM
    Air/Fuel Mixture Adjustment Springbok93 W124 E,CE,D,TD Class 4 07-15-2009 03:57 AM
    300TE Won't Start - Air Fuel Screw & Kids Stickman W124 E,CE,D,TD Class 8 09-30-2008 10:30 AM
    Air-fuel Mixture Screw Is Screwed Up! Stickman W124 E,CE,D,TD Class 2 07-04-2006 10:29 AM
