Window switch W107 500SL - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 02-07-2010, 08:55 PM Thread Starter
Date registered: May 2008
Vehicle: W107 500SL. 300CE-24 1990 1988xjs Jag
Hi
I'm having trouble with the RH window sometimes works sometimes dosen't.
How do i remove the switches to interchange them to see if it is the switch.
If not the switch my next posting will be How do i remove the door lining.
Does anyone know where i can purchase a workshop manual for a W107 500SL 1985 model.
Regards
Robert
Rufus.1948 is offline
post #2 of 7 (permalink) Old 02-07-2010, 10:20 PM
rowdie's Avatar
Date registered: Jun 2008
Vehicle: 1986 560SL: '84 500SL: '84 280SL 5 speed: other 107s
Quoted: 102 Post(s)
The switches just snap into the wood an can be removed by carefully prying them up with a thin blade. Make sure to protect the wood to prevent damage. The wiring usually is pretty tight so not in all cases can you disconnect the plug in.
The other choice is to remove the ash tray and bracket. This will allow access to the screws that hold the lower wood console. Once the screws are removed the wood piece needs to be pushed to the rear approx. 10mm to release the back which has a (for lack of a better word) tit or male plug that is inserted into the console.
I have a 500SL and I have heard the manuals turn up in the UK but are pricey. There is a 5 DVD set that a few of us have ordered to see if they contain the necessary info.
Good luck. Several members here from down under.
rowdie is offline
post #3 of 7 (permalink) Old 02-08-2010, 08:30 AM
Guest
Date registered: Dec 2006
Vehicle: ...
I strongly suggest pulling both window fuses and checking them. Hell, replace them! Make sure they are brass, not aluminum, then test your window. I could tell you a long story...
xxxxxxDingo Joe is offline
post #4 of 7 (permalink) Old 02-08-2010, 08:53 AM
reno4u2's Avatar
Date registered: Dec 2009
Vehicle: 1988 560SL (California Model)
Quoted: 730 Post(s)
I found this site helpful
reno4u2 is offline
post #5 of 7 (permalink) Old 02-08-2010, 02:37 PM Thread Starter
Hi gents
Removed and cleaned switches and replaced both fuses window now working again.
Thanks again
Robert
post #6 of 7 (permalink) Old 02-08-2010, 03:26 PM
Date registered: Sep 2008
Vehicle: 1975 450SL
Quoted: 15 Post(s)
Just for future reference:
Just put a small film of dielectric grease on the contact points of the fuse or the plug of the switches, this will keep air and moisture away. No moisture or air will significantly reduce corrosion, which tends to be non-conductive.
RadioTek is offline
post #7 of 7 (permalink) Old 02-08-2010, 03:27 PM
smack's Avatar
Date registered: Sep 2006
Vehicle: 1973 450SL 1991 420SEL 2017 Chrysler 300
Quoted: 21 Post(s)
Originally Posted by Rufus.1948 View Post
Hi gents
Thanks again
Robert
An MB Forum sucess story. Good work, Robert. Good advice all you helpers.
My Mercedes keep me so broke, I can't even pay attention!!
smack is offline
    WTB: A 1998 & up SL500 & a 500SL in a W107 Chassis 67300se5spd For Sale/Wanted/Trade/Giveaway 0 06-13-2009 10:50 AM
    WTB: OEM original black shifter knob for automatic 81-85 w107 SL (380SL,280SL,500SL) 107_AMG For Sale/Wanted/Trade/Giveaway 0 03-24-2009 01:54 AM
    Camber/caster settings for a 82 500sl w107 Damian R/C107 SL/SLC Class 2 07-09-2008 12:46 AM
    Mercedes W107 500SL WOOD TRIM nav_bhandher R/C107 SL/SLC Class 1 11-02-2003 01:03 PM
    Mercedes W107 500SL Recaro seats nav_bhandher R/C107 SL/SLC Class 0 10-31-2003 01:57 PM
