Odometer Repair: Tutorial - Page 6 - Benzworld.org - Mercedes-Benz Discussion Forum
» Auto Insurance
» Featured Product
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Roadster Forums > R/C107 SL/SLC Class
Old 03-07-2010, 02:25 PM   #51 (permalink)
GlueckAuf's Avatar
Date registered: Sep 2009
Vehicle: 1987 Mercedes-Benz 560 SL
I believe that's by design. The two counters operate independently.
Zero your trip odometer exactly when the main odometer mile changes and I believe they'll be in sync. (Unless I misunderstand.)
Good road,
GlueckAuf
Sterling Heights, MI
1987 Mercedes-Benz 560 SL Benzedrine
2002 Volvo S80 T6
2004 Litespeed Vortex/Campagnolo Record
GlueckAuf is offline   Reply With Quote
Old 03-07-2010, 03:57 PM   #52 (permalink)
abiby's Avatar
Date registered: Jul 2008
Vehicle: 82 380SL 96 SL500
Well, duhhhh.....
Alan
If it doesn't fit, force it.
If it breaks, it needed replacing anyhow.
abiby is offline   Reply With Quote
Old 03-07-2010, 06:05 PM   #53 (permalink)
nobby's Avatar
Date registered: Feb 2005
Vehicle: '83 280 SL 5 speed - The PIG
Good road,
I was thinking the worst. Never considered the easiest.
I'll try that.
Thanks.
An eye for an eye only makes the whole world blind.
nobby is offline   Reply With Quote
Old 03-07-2010, 06:12 PM   #54 (permalink)
Date registered: May 2009
Vehicle: 1985 380SL; 2004 E320; 2007 GL450
Great tutorial, Herr Nobby. I just checked my odometer gears expecting to find nothing awry as it's never missed a beat tallying the miles on Benzedrine--but wouldn't ya know, I'm missing a single tooth on gear E1.
I ordered the set to fix this issue, too, before my instruments go back in.
I might add that in looking at my gears, the number of teeth is marked on each one. If you clean away the grime, you may as I did find the markings "z16" and "z48" on gear E3, and "z12" and "z48" on gear E2. ("Z" stands for zahn, deutsch for tooth.)
This might help ensure others order the correctly-toothed E3 from Odometer Gear, as this particular gear's inner cog is available in 12, 13, 15, 16, and 18 teeth. (And especially if an indeterminate number of teeth have broken off!)
Again, you're a hero, bud. Great piece!
Good road,
Thanks for pointing out Z(ahn) represents tooth. Now I do not need to count the number of teeth.
bluewater1 is offline   Reply With Quote
Old 03-08-2010, 01:59 PM   #55 (permalink)
gerkebi's Avatar
Date registered: Oct 2005
Vehicle: 107, 115, 116, 123, 124, 126
gerkebi is offline   Reply With Quote
Old 03-08-2010, 07:01 PM   #56 (permalink)
GlueckAuf's Avatar
You're welcome, bud.
One other bit of news I should pass along on the topic of odometer gears is the response I got from Odometer Gears when I inquired about the apparent noisiness of their hard plastic, dry-installed gears vs the soft, factory-greased OEM gears:
"Rarely, we do hear this complaint in the Mercedes 107 chassis. The cure is to apply a thin layer of wheel bearing/axle grease in the teeth of the E2 and E3 outer part of the gear (the 48 tooth count section). This will deaden the noise and cure the concern. The grease will not degrade our new gears like it does on the OE gears. The OE gears fail because the grease reacts with the urethane and causes them to break down and become waxy and fail.
Kind regards,
Darren Shackelford
Odometer Gears Ltd.
72 Croatan Road
Newport News, VA 23606
757-593-3478
757-771-6694
So there ya go!
Good road,
Old 03-10-2010, 12:07 PM   #57 (permalink)
2minibenz's Avatar
Date registered: Nov 2009
Vehicle: 1983 300D Turbo , 1983 380SL , 1995 E320 Limited Edition
Thanks! I put this off for over a year mainly because of trouble trying to remove the steering wheel. I found that your tutorial, and others on the wheel removal, made this an easy project. Use a heat gun for a minute or two to heat the hex bolt and the wheel removal is an easy job.
I do have a guestion in regard to the cluster housing. After disasembly and cleaning it now has a gap between the lens and housing that I don't remember. I have taken it apart twice and it looks correct but...........?
Steve
2minibenz is offline   Reply With Quote
Old 03-12-2010, 07:54 AM   #58 (permalink)
Always Remembered RIP
ussun's Avatar
Date registered: Jun 2006
Vehicle: 1973 450 SLC AMG, 1995 Chevy Tahoe
My trip miles counter stopped last fall.
But it started on it's own this spring so.
So I'm glad I didn't have it fixed.
PS. I can only hope your sl's c's are driving as nice as mine is
Ah that magic feeling of being post mortgage and zero debt. (between repairs)
ussun is offline   Reply With Quote
Old 03-12-2010, 10:52 AM   #59 (permalink)
2minibenz's Avatar
It is just a matter of time on the odometer repair. The three gears turn to mush and fall apart.....but it is an easy fix so don't worry.
Also I see the light....through the gap in the housing...and that is a good thing. I just did not remember it being there when I disassembled every thing.
Old 03-16-2010, 08:52 PM   #60 (permalink)
nobby's Avatar
Good road,
It worked. Thanks.
Bookmarks
Need to repair odometer. mrlightrail W126 S,SE,SEC,SEL,SD,SDL Class 10 05-04-2012 04:52 AM
Good Duo Valve / Duovalve DIY Repair Tutorial xvvvz W202 C-Class 2 11-05-2011 01:17 PM
ROUGH DRAFT-Tutorial: Odometer Repair nobby Test 17 03-06-2010 01:40 AM
Odometer repair 420 SE W126 S,SE,SEC,SEL,SD,SDL Class 8 05-09-2009 05:59 PM
Odometer Repair rondor2 R/C107 SL/SLC Class 14 04-03-2009 07:43 AM
