How do you lift your SL - Mercedes-Benz Forum
post #1 of 19 (permalink) Old 12-07-2009, 06:11 PM Thread Starter
rockcrusher's Avatar
Date registered: Nov 2009
Vehicle: 1984 380SL, 1973 450SLC
Quoted: 153 Post(s)
Been playing with the 380SL for two years now, and find that raising her high enough to play underneath is not simple. Checked around for lifts, nothing I thought reasonable for part time use. Just wanted to hear what everyone else is doing, idea's. Used the hydrolic jack with wood cusion to use under the oilpan, (ouch ), and the differential. then jack stands.... Does anyone make an adaptor for use at the manufacturers jack points, that plug into the holes, and allow for a hydrolic lift. I have just used the rocker panel area, that hurts also. Looking may be to develope something. also is there anyone in the Winder Ga. area that might let a friend look at thier SL for a sample...
rockcrusher is offline
post #2 of 19 (permalink) Old 12-07-2009, 06:23 PM
MBGraham's Avatar
Date registered: Oct 2006
Vehicle: '72 350SL, '85 300D, '98 E320, '14 GLK250
Quoted: 8 Post(s)
I've always jacked the car using the the channels that are part of the body just inside of the rocker panels. But it is tight in there for a jack and jackstands.
I have never lifted the car using the engine sump. Does anyone do this? It it workes OJ, it should be easier to just jack in one place instead of two, then slip jackstands onto those chassis beams.
MBGraham is online now
post #3 of 19 (permalink) Old 12-07-2009, 06:43 PM
Huntrtylr's Avatar
Date registered: Jan 2009
Vehicle: 1982 500SL AMG "Darmstadt Branch"
With her help...
1982 500SL AMG Schwarz (040) Schwarz (231) "Fully Documented"
"JACQUELINE"
Huntrtylr is offline
post #4 of 19 (permalink) Old 12-07-2009, 06:45 PM Thread Starter
Quoted: 153 Post(s)
I was thinking about air bags, but silicone is ALOT BETTER>>>> lol
post #5 of 19 (permalink) Old 12-07-2009, 06:48 PM
Huntrtylr's Avatar
Just kidding above in all seriousness...If it's nothing major that requires taking wheels off...I use Rhino Jacks
ID:	278005   Click image for larger version
"JACQUELINE"
post #6 of 19 (permalink) Old 12-07-2009, 06:49 PM
jplinville's Avatar
Date registered: Sep 2008
Vehicle: 1987 560SL
Send a message via AIM to jplinville
"Use the Force"
I'm not a real dickhead...but I acted like one in high school.
jplinville is offline
post #7 of 19 (permalink) Old 12-07-2009, 11:05 PM
GlueckAuf's Avatar
Date registered: Sep 2009
Vehicle: 1987 Mercedes-Benz 560 SL
I second the Rhino Ramps. That's the only lifting and supporting device I bet my life on, literally. You just can't do any "wheels off" work, obviously.
For that, the "by-the-book" method (meaning the official factory manual) calls for using "jacking up shoes", MB Part #123 589 11 63 00, as described on this attached page. I've not researched them, though, let alone used them, and I'm not certain they're even available anymore, or what they cost. But it's probably worth looking into, since it's the method Mr. Benz recommends to avoid damaging your expensive Mercedes. (And your even more expensive you, I presume.)
Good road,
Name:	Mercedes Jacking-Up Shoes.jpg
GlueckAuf
Sterling Heights, MI
1987 Mercedes-Benz 560 SL Benzedrine
2002 Volvo S80 T6
2004 Litespeed Vortex/Campagnolo Record
GlueckAuf is offline
post #8 of 19 (permalink) Old 12-08-2009, 03:26 AM
Weather Man's Avatar
Date registered: Dec 2008
Vehicle: 1984 380SL
Quoted: 166 Post(s)
I like the ramps, too, for getting under to inspect. The extra 6" is good enough. Actually I used the car's own jack for the first time about a month ago, just to test it. The fronts are too rusty to trust, for the front I bought a small hydraulic jack but the rears worked fine. Now I know I can at least change a tire if I have to.
Weather Man is offline
post #9 of 19 (permalink) Old 12-08-2009, 04:09 AM
Date registered: Nov 2008
Vehicle: 1988 SL560, 1989 560 SEL
I thought this over and decided to go to a friends garage who has 2 lifts. one for frame amd one for wheel lift. Plus I get free advice while there.
rondor2 is offline
post #10 of 19 (permalink) Old 12-08-2009, 04:17 AM
Huntrtylr's Avatar
A good safety thing to do (oh no not my pentas) is to place wheels like this picture just in case.
"JACQUELINE"
    Pre face lift/post face lift question tommyb2b W140 S-Class 2 12-07-2008 10:46 AM
    Ml lift daytripper General Mercedes-Benz 3 12-08-2006 03:05 PM
    Replace pre-face lift seats with post-face lift Jonas_Gothenburg R170 SLK-Class 4 05-28-2006 04:42 PM
    Exchanging pre-face lift door handles with post-face lift ones... Alan (Chicago) R170 SLK-Class 3 05-02-2003 01:01 PM
    Pre face lift vs. Post face lift... Alan R170 SLK-Class 4 12-14-2001 07:05 PM
